DCT owners
2,266
813
The board is glued down and any attempt to remove it will likely crack the board. For a maybe I’m not prepared to do that just yet
Nisse Järnet
56
59
BMW E30 turbo 4wd
Yes, I'll try to apply heat and see if I can get it out without damaging the cables.
We'll see :)
2,266
813
It looks like silicone based heat compound however it’s set like glue and doesn’t seem to be too worried about temperature as it would be designed to retain its physical properties even under these circumstances. My guess is that it will require removal using mechanical means and likely destruction ☹️
  • Sad
Nisse Järnet
56
59
BMW E30 turbo 4wd
Yeah you're probably right, they wouldn't use anything with low resistant to heat in that spot
But I'll try :)
Reactions: aus335iguy
