DBV2 Twin Scroll Bottom Mount
Red90
46
20
E90 335i
looks really good, any idea when it will be on the market and final pricing?
Clean WHP
173
136
2010 135i Msport 6MT
With this much skill I wish you went T4 and killed it. Looks fantastic though, keep it up!
Isn't Motiv kit a T3 also? If so it doesn't seem to be stopping them seeing as they have the highest dyno (or one of) ever for the N54.
Ive spent the last 10-15 mins searching to see if Motiv is T3 or T4 and cant find an answer. I once saw somewhere it was T3 but cant find it now. Can anyone confirm?
2,198
On what engine/turbo? More info?
AFAIK this is the largest T3 turbo on the market. Someone please feel free to correct me: https://shop.boostinperformance.com/product-p/fp-super99-turbo.htm
Compressor wheel - 94HTA
Flow Rating - 95LB per minute
CW Measurements - 67.7MM Inducer / 94MM Exducer
TW Measurements - 76MM Inducer / 67MM Exducer
Compressor Housing - FP1S Compressor Cover 4" inlet 2.5" outlet
Turbine Housing - FP .85 T3 TH
CHRA - 10MM T4 BB
Oil Line - Not Included
A 6466 is around 90 lb/m IIRC.
Compressor Wheel 64.39mm inducer / 86.61mm exducer
Turbine Wheel 74.17mm inducer / 66.00mm exducer
Compressor Cover Ported S (4.0" inlet/2.5" outlet)
A 6870 Gen2 110 lb/m
Not sure if you can get 1k out of the super 99 it...probably gets close.
edit: http://www.motoiq.com/MagazineArtic...urbine-Housing-for-GEN2-PT6870-CEA-Turbo.aspx <--I am guessing this must be the turbo. Assuming it gets 110 lb/m out of it like the T4.
2,198
I'm not google and I stopped spoon feeding my own son when he was 1y old.
lol
John@DBV2
319
201
Those circles look to be wastegate ports.
Are you going to do one wastgate or two? recirc or dump tubes?
How's the compressor inlet / outlet going to be routed? Are you going to use a custom motor mount arm or fab the downpipe to go around the stock one?
It’s a single Wastegate with a divider up to the waste gate between scrolls.
We’ll have photos of everything soon so you can tell better. Words don’t do it justice. It’s dump tube as well. We have made an engine side mount, not a motor mount. Not sure if I’ve explained that properly but there’s a piece that bolts to the engine, which bolts to the mount. We felt it was better to leave the engine mount choice to the customer and built the other mount. Not everyone like the same NVH levels right.
John@DBV2
319
201
CHRA - 10MM T4 BB
100 percent there are larger turbos out there. The hot side is actually only a 0.85AR on that one at the top, we can bolt up a 1.01AR or a 1.06AR if you guys really want it. There will be many options, which is the beauty of custom turbos.
John@DBV2
319
201
We’ll release that soon. Sub $5K USD is all I’ll say as of now with a promo for buying during the intro of the kit being a larger discount on top of that. BETA kit is just about touching $4K USD.
John@DBV2
319
201
I’m spamming now because I suck a foruming but again, T3 will be just fine and make some stupid power. And on top of that, you want to spool at 4500 and still run 10’s, it’s your car. But I’d rather have my turbo spool as fast as possible, have a usable amount of power that I can daily drive and really enjoy it. I don’t want to build my engine, I don’t want to run methanol or E85(don’t have it here) or port injection. I want to drive to the gas station fill up and then blow the doors off some guys Lambo.
Not saying the kit isn’t capable of stupid numbers, because it surely is. I’m just stating my own reality and most of us are in that same boat. And again, I really appreciate the conversation and debate. Thanks again.
Reactions: boostE92d
chadillac2000
233
255
NC
2008 BMW 135i
How do you plan on doing that? You planning on running straight pump gas on this? Shotgunning the HPFP?
