Custom Big Single Turbo To Custom Twin (S55) Turbo upgrade
Dumaurier7
690
315
! purchased a complete S55 HPFP system for $225! it's crazy that these parts were over $2000 just couple years ago! For anyone who is unsure (as I was) it does bolt up directly to the N55
This year nobody gets anything for Christmas!!!!! :laughing: ...... ' cause I also bit the bullet and purchased the Nostrum S55 HPFP kit!!! Will post pics when I receive it as it is stuck in customs right now due to the increased "Christmas Rush" volume.
  • Love
Dumaurier7
690
315
Just received this kit after a lot of back and forth with customs! But all is still good, next on the list will be cams and an EOS intake manifold, and a set of stage 3. (Upgraded S63) injectors later down the road.
Reactions: houtan and wheela
Dumaurier7
690
315
After checking everything to ensure I got all the components, I found that an important T bracket for mounting the fuel splitter block was missing!
Today I decided to install everything to make sure nothing else was missing and that it all fitted as it should.
Thankfully it all went together as designed.
Reactions: houtan
Dumaurier7
690
315
On another note, I came up with a way to keep the turbo charger circulation pump ..
The pump will take suction off the discharge header of the main engine pump, push the coolant through the turbos and empty into the block, reverse to the S55 but same as the N55 flow. This addition will eliminate the need to have it coded out, provide higher cooling flow and allow the after switch off cooling (not sure if the N55 did that too) either way it’s a win win I my humble opinion, the only negative is that I had to cut up and modify the water delivery pipe yet again☹️
Once I receive the intercooler pump I’ll be doing a similar configuration, the hot water from the intercooler will go to the original pump which will then pump it through the coolers , from there both outlets from the coolers will join into one -16AN hose to feed the Davies Craig EWP 135, as above this will boost the flow through the cooling system to improve its performance.
Reactions: houtan
