FS Custom 335i cluster Virginized White LEDs 200 mph/backlit 335i logo Working M3 style variable redline
LMB335is
301
189
FOB FL
13 335is
Custom 335i cluster I made, one of many I can do. Virgin 335i cluster, white LEDs used for gauges and LCD screen, custom gauge faces, real replacement faces, not overlays, with 200 mph speedo and backlit 335i logo on the tach faces. Speedo has been rescaled. It has working M3 style variable redline which uses coolant temp. Cold start it rotates to 4500 rpm, rotating to 7k redline when warm. It will need to be default coded with NCS Expert or bimmergeeks protool app to write your VIN and VO to it. It will work correctly and error free once that is done. $325 shipped with a $25 refund if you send in your old cluster.
1,573
Can you build one with Amber Leads like stock, 200mph with variable M3 style redline set to 4.5k warmup and whatever hot redline we want?
LMB335is
301
189
FOB FL
13 335is
I can do whatever LED color combo you want . Leave them all factory orange, white gauge LEDs and factory orange LCD screen LEDs, etc. Blue, red, purple, green, yellow, are all available Leds. The start and finish point can be manipulated but you're limited to what the gauge face itself will show. These faces have a hard 7k redline like the factory faces so no matter what the variable redline is set to on the redline end it will still look like a 7k redline. M faces have the hard redline at 8300 rpm so there's more room to play with.
1,573
Nice. Might get it touch with you once I get my redline and tune figured out with the new hardware.
