Pre-LCI/Early 07 335i Auto ZF Trans - Slightly NOT stock
Car acts totally normal, lights come on, everything is good... click ignition button on, pump primes and never goes off, water pump can be heard turn on, clicking in engine bay just like normal when ON is pressed, car cranks strong... no start, no fuel smell. Cant communicate with DME via known good MHD and OBD2 Blutooth w/Torque
Mods
Currently working on the car, this is my TLDR version... will add full version later, hoping for some ideas to try asap. Ive had similar issues before with this car but always figure it out eventually. I could strangle some german bmw engineers right about now though.
Any help is greatly appreciated, I dont give up easy... it WILL start just a matter of time. :burnrubber:
Thanks!
- new built motor installed after car sat for 1 year no battery
- no start
- no dme communication
- no fuel injecting into engine
- fuel pump constantly priming/circulating gas when ignition is on
- jb4 completely removed
- new fuel pump and fuel pressure regulator
- checked all glovebox & DME box fuses multiple times
- swapped DME for backup 2nd cloned DME
- checked/bypassed blue dme relay and 30g fuse box relay
- checked all engine sensors are installed and proper plugs connected to engine
- checked main ground strap & power wire to/from starter & alternator
- battery voltage ~13 when off of charger but charger is left on charger during all work
- disconnected IBS sensors to battery
Mods
- Engine - Forged Rods/Pistons/Ported Heads
- Hybrid Stage 2+ Turbos
- Index 12 Injectors
- NEW Stage 2+ Fuel Pump
- Charge Pipe w/Tial BOV
- 3.5 Bar MAP
- Big Aftermarket Intercooler
- Relocated Inlet/Outles
- Downpipes
- Borla Sport Exhaust
- Catch Can
- PCV Valve
- JB4 BEF w/MHD (currently removed)
Thanks!
