video below. This is my fourth time, 6 hours into attempting to bleed the clutch. Bleeder screw generously loosened, with a vacuum reservoir being powered by an air compressor running at a constant 20psi of vacuum. As you can see in the video only a few drops get sucked down. However af the end you can see the reservoir is completely full. Desperate for any solutions, shop is not an option anymore due to how modified this vehicle is.
**want to mention i’ve already replaced with a new slave cylinder, billet clutch delay valve, full fluid flush, and new throwout bearing and clutch fork to name a few. “
