NOTE: You must read carefully all the information provided.
Again, you must carefully read and follow ALL instructions a couple paragraphs down to be entered!
CONTEST DETAILS:
This month we are featuring Clark Performance Fabrication as they have agreed to raffle off TWO (2) Differential Lockdown Braces with CPF T-Shirts for our monthly raffle! This means there will be two separate winners!
PRIZE DESCRIPTIONS:
The 135i’s and 335i’s are notorious for a sloppy rear end from the factory. The cause comes from the soft rubber differential carrier and subframe bushings allowing the differential to flex vertically putting all the excess torque into the rubber instead of the road. This bracket prevents the vertical movement of the differential without changing drivability or adding any NVH.
The braces fit AT and MT, E82, E90, and E92 models.
More information here:
https://clarkperformancefab.com/collections/frontpage/products/differential-bracket
Enter the giveaway by following the instructions listed below then head over to the Clark Performance Fabrication website and take a look at what they have available!
Check them out here:
INSTRUCTIONS:
To win, you must do ALL THREE(3) things:
The drawing will automatically occur on the last day of the raffle month. Our system detects fake/duplicate accounts and offenders will be automatically disqualified and potentially humiliated. You may click "View Entries" to verify that you are indeed entered.
CONTEST DETAILS:
PRIZE DESCRIPTIONS:
INSTRUCTIONS:
- Like the CPF Facebook Page - click here: https://www.facebook.com/clarkperformancefab/
- Comment in the N5X Enthusiasts giveaway post, here: N5X Enthusiasts
- Participate in the raffle (Below). You may enter as many times as you want! Each raffle ticket is 25 credits, you earn them by posting replies(5+), making threads(10+), referrals(25), etc. If you look at the top of the page and see you don't have enough credits or you run out, the above actions will generate more. To enter the raffle, ensure you have at enough credits and enter below.
