Currently I am using Charge Pipe Methanol, 80/20 mix with a 1000ml nozzle.
The car works ok for the most part other than timing corrections, made 565whp on pump fuel. 26psi and 10.5 peak timing, however plenty of timing corrections.
A friend has sold me his Port Meth setup with 6x 220ml nozzles, so I'm thinking i'll also use a small one in the charge pipe for a total of around 1500cc of methanol mix.
Am I likely to notice much difference changing to this setup?
It seems a safer way to go?
Cheers
Charles
Cheers
Charles
