Car won't idle 2A9E 2CFB 2D09
4,345
Plugged head ports and I've got a bunch of issues I've never had before crop up. Cars been down since January so I'm finally trying to start it up.
Waleed
Hello all, I have E60 2008 n54 and I just changed water pump after that all those codes up become in my car so I believe that it's an electrical issues I tried to find F37 fuse but I couldn't because no fuse diagram in my car please if you can guide me to this fuse place please
Stuart1900
Hello, just found your post, I have a 08 535xi with the same exact codes and issues. I have not been able to figure out what it is. Where was the location of f37 for you? I’ve been searching but all I get online is the location for a 5amp fuse.
Nov 13, 2023
Problem has been fixed, all codes have been resolved by changing fuse F37. I checked earlier but looked at the wrong diagram, I needed to locate and check my own fusebox diagram.
This fuse and relay X60003 power a bunch of sensors and apparently the throttle body relies on it. Without starting the car, I can now see the throttle blade twitch during ignition on.
i created an account just for this.
car came in with a blown belt stuck on crank pulley. pulled the pan, vc and cleared all the debris. upon start up we had timing codes.
Nov 13, 2023
and after 2 weeks of chasing my tail i found this thread... same thing as you checked fuses with an incorrect diagram
Ofeeski
Is the F37 fuse located in the glove box? When I checked the diagram on Google its saying the fuse is for these
- ULF (Universal Charging & Hands-Free)
from 03.2007:
- ULF-SBX
- TCU (Telematics Control Unit)
- ULF-SBX-H
- USB hub
