Technical Boost Referenced Fuel Pressure Regulator
veer90
1,000
774
West Nyack, NY
e90 335i 6MT
Question:
For boost referenced FPRs, is there any ratio available other than 1:1?
Context:
I'm eventually planning on putting together an overkill fuel system for 35+ psi with ST and e85: triple walbro 450s, FPR with return line, ID1000s or 1300s on the PI rail, etc etc. If I used a 1:1 FPR and a base fuel pressure of 72 psi which is factory, the fuel pressure at full boost would be over 100 psi. ID says 100 psi is the max fuel pressure for their injectors.
A lower ratio on the FPR would be ideal, say 2:1. I was also thinking about dropping base fuel pressure to around 50 psi, which will make the car set 2AAF fuel pump plausibility at low load but otherwise be fine.
Input/ideas appreciated
veer90
1,000
774
West Nyack, NY
e90 335i 6MT
don't you need to maintain a pressure difference for the injectors? at 75 psi static FP 35 psi boost the pressure difference across the injector is only 40 psi. or does it not matter?
Payam@BMS
412
265
34
Why are using the boost reference at all? Just set static pressure to 75 psi, plug the reference, and you are done.
Agreed. I was doing 1:1 but static is much better. I did mine at 80psi static so when I do 40+ psi runs my lpfp/PI will still be at 40psi.
veer90
1,000
774
West Nyack, NY
e90 335i 6MT
interesting...
at 80 psi did the car throw any codes? I know it's real finicky when the fuel pressure is not factory.
