BMW X5M/X6M Aluminum Pan retrofit, ZF 6HP
Ty_Bo
18
10
Livermore, CA
2009 535i
Hi Everyone,
This is research I wish I had done before changing the transmission filter in my 2009 535i. Hopefully this becomes a clean-cut guide of which ZF 6HPs are compatible with aluminum pan retrofits. Specifically these part numbers:
http://bmwfans.info/parts-catalog/E70/USA/X5_M-S63/browse/automatic_transmission/ga6hp26z_oil_pan
E70 X5 M/E71 X6 M Pan
24-11-7-588-752
E53 E70 E71 Filter
24-15-2-333-899
For context, I saw a facebook post from Josh LeBlanc of LeBlanc Motorwerks showing off some of his work on an X5 3.5d, including an aluminum finned trans pan retrofit from an X5-M:
He's likely a better source for firsthand experience, but ZF appears to use their plastic pan/filter across a wide range of chassis and ZF 6HPxx transmissions, and there should be some cross compatibility with this finned aluminum pan.
If anyone knows a good resource to look up which 6HP units are in which cars I would love to be pointed in that direction. I’ve been able to verify that these aluminum pans work on X5 diesels and the 335d, which I believe are the 6HP26 or 28.
per FCP Euro, their plastic pan “GA6HP19Z” service kit fits the following cars, and I’d like to update with specific transmissions:
PlatformModelYearTransmission
X53.0si2007
2008
xDrive30i2009
2010
X6xDrive35i2008
2009
2010
X1xDrive35i2013
2014
Z43.0i2006
2007
2008
3.0si2006
2007
2008
sDrive30i2009
2010
2011
1 Series128i2010
2011
2012
2013
3 Series325i2006
325xi2006
328i2007
2010
2011
2012
2013
328i xDrive2010
2011
2012
2013
330i2006
330xi2006
335i2007
2008
2009
2010
2011
2012
2013
335xi2007
2008
335i xDrive2009
2010
2011
2012
2013
5 Series525i2004
2005
2006
2007
525xi2006
2007
528i2008
2009
2010
528xi2008
528i xDrive2009
2010
530i2004
2005
2006
2007
530xi2006
2007
535i2008
2009
2010
535xi2008
535i xDrive2009
2010
7 Series740Li2011
2012
per FCP Euro, their aluminum pan “GA6HP26Z” service kit fits the following cars:
X54.4i2004
2005
2006
4.8is2004
2005
2006
X5 M2010
2011
2012
2013
X6X6 M2010
2011
2012
2013
2014
AlpinaB72007
2008
I hope this sparks some discussion and I can develop it into a somewhat comprehensive resource for the community
  • Love
Reactions: JohnDaviz
