Here is the diagram from Vargus I updated. You need to add a check valve that prevents vacuum through the high side catch can and you need an adjustable vacuum relief valve added to the valve cover or crankcase access port. There is one on the front of the head for instance.
Once you put all of this in you need to check vacuum in two places.
1. Intake manifold needs to be within the std 18-22 in/Hg. You can hook up a $15 vacuum gauge to the BOV line. Mine now sits at 20 in/Hg and resolved all my AFR issues.
2. Crankcase vacuum. Mine right now is sitting at 3 in/Hg and that keeps air from being pulled through the main seals, which you will HEAR if that happens.
The 10-14" of vacuum VTT mentions on their valve, I don't know how you'd even get it up that high without all of your engine seals sucking in air. Stock vacuum for instance is around 0.5 in/Hg so 10-14 is incredibly higher than stock. Anything over 4 in/Hg and my rear main seal starts to whistle and ALL of my engine seals are brand new and OE. With the right intake and crankcase vacuum, the car will feel healthy. You'll notice the difference.
Let me know if you have any other questions.
