BMS BOV ADAPTER REVIEW
3,624
Hindsight ... too many years for me running vacuum side only cars lol. I should make mine better. I like the set screw or machine screw idea, add some sealant to the thread and that should do it.
2,197
Reason I do not like that is to do it correctly you need to drill and tap it which means you have to remove the IM. I know a correctly sized screw will work but if you go too large and crack it you have a whole load of bigger issues now ;)
Another easy/quick solution would be 5 minute epoxy or plastic weld.
3,624
I agree but I might be lazy on this and tap that sucker in place. It's a fine thread cut, pretty thin and plastic shavings ... what could go wrong?!?! ... I mean I never have problems with anything else on my car :tonguewink: ... think I'll tap and send it. Waiting for someone to tell me the thread size for the hole (talk about being lazy!)
  • Love
1,929
664
Totally misread his comment. Again..engrish
Yesssssss finally wasnt my post
Silicone is unstoppable if you use good stuff I siliconed a brick to a wood fence at my yard and did pull ups until a larger worker broke the fence , but it still was stuck to the brick. I think plastic weld or silicone with a cap close to the nipple size so looks nice would be perfect maybe even the cap from the plastic weld lol.
The earlier posts should be edited to add at end that their is boost cause that shit had me cross eyed thinking I was dumber than i really am.
2,197
Or....just say F it and use a wood/deck screw you will be good to go my friend!
No chance of it cracking the plastic.
