Bimmergeeks Pro Tool and Bluetooth Dongle discussion
I have seen options for editing Vin on modules I will check tonight for you
Thanks, Rob. If this helps, this is the NCSExpert process:
1. Load NCSExpert.
2. Load Profile and select or load a Dummy Profile
3. F1 (VIN/ZCS/FA)
4. F3 (ZCS/FA f .ECU)
5. Choose E89
6. Select CAS
7. F6 (BACK)
8. F4 (Process ECU)
9. Select the RDC Module to revert to stock (Both RDC's show up - RDCLC)
10. F2->Choose "SG_CODIEREN"->ok
11. They Execute and press OK on the dashboard when it appears to reset.
1,923
662
Def can do it I didnt actually write module but you have access to cas and you can go to advanced coding but it also listed edit vin as a shortcut so worse case you can manually do it but it seems to have the framework to run scripts for alot of things.
Reactions: fmorelli
fotodadi
E89 Z4
Hi everyone.
I have the Bluetooth dongle and am using the Protool app and all works great. Recently had to replace my windscreen and found I needed to "initialize" my Rain Light Sensor for it to work with the new windscreen. Tried, but can't seem to find how to get this done with the app. Any pointers will be greatly appreciated.:innocent:
