B58B30 gen1 pneumatic wastegate
tuningB58
Hello world!
Can anyone help with modifying the DME firmware to use the pneumatic wastegate with separate boost controller, disable MAF sensor, disable fueltank ventilation sensors/valves and engine head ventilation sensor, disable fuel leak sensor, second lambda?
Also need to disable all errors about airbags and about disconnected seats ECU's.
tuningB58
Maybe someone can tell me the addresses of forums where I can find specialists, who deal with DME firmware changes?
If there aren't any...
valpfrmnc
40
31
Its easier to buy a Motiv Reflex+ and integrate over can bus. If properly integrated you can send the WGDC to the motiv over can and it converts it to a DC on its aux outputs where you connect your boost solenoid. If fully integrated you can also do all changes on the DME directly instead reflashing the Motiv. The rest you mentioned can be done via damos and using a funktionsrahmen. Hit me up if you need help.
