ATM Race Exhaust 3.5” Single. So much nicer then VRSF!
Slow335is
89
Minneapolis Minnesota
www.youtube.com
Single turbo 335is
My new video is up showing my new ATM Race Exhuast single 3.5” on my N54 BMW 335is. This is so much nicer then VRSF and sounds better too. Overall quality is way nicer and doesn’t have a huge muffler and isn’t straight piped its the perfect middle ground. I have a single turbo set up and included some sound clips and more. Also showing more modifications I have installed.
Like always please take a minute to follow/subscribe my 2011 BMW 335is build online on the following platforms. Mod list is down below as well.
YouTube 📹
Facebook 📲
Instagram 📸
Mod list for Nicks 2011 BMW 335is I’m sure I’m forgetting lots of things.
Doc Race Kit Precision gen 2 Dual Ball Bearing T51R mod Cold side coated illusion red hot side heat ceramic coated
GFB 3 boost controller with 4 port Mac solenoid
AEM wideband
Nitrous set up wired to steering wheel
VRSF 1000HP 7.5 stepped intercooler
VRSF charge pipe with tial QR blow off valve 10psi spring
Wedge Antilag kit wired to steering wheel
Fuel it stage 3 low pressure fuel system. Dual bucketless Walbro set up. Dual 525 Walbro with one on a 15psi Hobbs switch.
Spool performance Helix HPFP overdrive 4x extreme model
Spool performance bluetooth ethanol analyzer and upgraded fuel line
M18 Modular valve cover coated wrinkle black with R8 coil adapter bracket in illusion red and all hardware illusion red including oil cap
Custom intake manifold coated illusion red
Bimmerlife Audi R8 coil upgrade
Burger Motorsports billet oil filter housing
Burger motorsports cowl filter delete
Burger motorsports large rear diff brace
Burger motorsports billet oil thermostat caps
Burger motorsports billet oil thermostat lid
Burger motorsports billet sport oil cooler valve
Nelson racing wheel carbon fiber paddles
2 step cooler NGK 97506 spark plugs gapped at 0.018”
Revshift 95a durometer racing transmission mounts
Rev shift 95a durometer racing motor mounts
BMW index 12 injectors
VTT billet crankcase breather
Drilled Zimmerman Z-coat rotors with Akebono ceramic brake pads for front
VTT ultimate 15” brake conversion kit, Wilwood drilled rotors,calipers, pads and stainless steel brake lines.
BimmerWorld Race bullet nose wheel stud conversion kit from wheel bolts for rear 15” Welds.
Weld Racing S79 17” light weight wheels for front 17x7.5 5.3” back spacing on Nitto 555g2 tires 225/45/17.
Weld Racing S79 15x9.33 6.5” back spacing wheels with Mickey Thompson ET Street R tires 275/50/15 for the rear
Mfactory built axles
Mfactory built LSD
ATM Race Exhuast with 4” custom black magnaflow tips
Rushcustoms Carbon fiber rear diffuser, Carbon fiber ARYKM style front lip spoiler M sport. Red start button.
SCHROTH Quick Fit Pro racing harnesses and cage to be installed
#N54 #SingleTurbo #BMW335is #DocRace #Precision #IN54NE #BMW #7SpeedDCT #ATM 2CBE9804-24A6-4701-9146-FFBC69A2F8DB.jpegE91D5D12-5AE4-4086-A7B5-065F54FC4E0C.jpeg661A70CD-57AC-488B-91ED-942269E95BB3.jpeg
derekgates
740
375
NW FL
derekgates.us
2011 335is
That exhaust looks great. I am in the market to replace my OEM on my 335is and was strongly considering VRSF. I still prefer having a muffler and option to have black tips... seems like that will be upcoming!
Thank you for sharing.
Slow335is
89
www.youtube.com
Single turbo 335is
Doesn’t come with black tips I didn’t use theirs either just a FYI. This comes with a resonator and they will have muffler options available too.
derekgates
740
375
NW FL
derekgates.us
2011 335is
Yeah, the tips are a minor problem; mine are beat up a little and would love an option to get a new set of black tips.
Muffler will be 100% required for me. Even the OEM exhaust is nasty and loud at times, hahaha.
Reactions: Slow335is
Slow335is
89
www.youtube.com
Single turbo 335is
