Athena cutring head gasket PROBLEM
Jspc_dhx
I bought a N54 cylinder head gasket at "5150", I also put in ARP cylinder head bolts and it was machined. The engine runs perfectly (Yesterday after some pulls around 25 psi I noticed this .... CR cylinder head gasket installed 100 km ago . In one part of intake side it manages to generate a small accumulation of oil. Will this stop? Is it normal? What do I.
*I could live with it, it's not a daily car . Would it be dangerous for the engine ?
*Assemble the engine following the manual step by step ( Torqued and re torqued to 95 lbs . some tell me to retorque to 100 lbs i only have ns300l on all 4 corners )
Thanks!
