FS Aluminum coolant/ps res
D3mon54
Aluminum coolant tank and ps res combo unit (divided internally of course). Includes everything needed to install, even relocation hoses, etc. This can uses factory level sensor. $375 plus shipping. Offer these in raw and black (extra $25)
How much to ship to 11235?
N54gasm
365
244
New Freedom
www.spoolnmotorsports.com
2008 BMW 135i
Updated pic ;)
Reactions: Thunderstorm1250
1,664
Does this reduce line length too?
Pretty interested in the black powdercoat combo tank. Would 100% require stock coolant sensor integration. Any downsides?
N54gasm
365
244
New Freedom
2008 BMW 135i
Well upper return hose is shorter but lower feed is about the same length. Cant keep oem sensoe, but i do have a e36 sensor that i use. Works with oem plug just need a minor trim to the guide feed plastic on the connector
1,664
Assuming it works to alarm low level before it's critical?
N54gasm
365
244
New Freedom
2008 BMW 135i
Ill get a better pic installed tomorrow. But will fit all E90/e92/e93/e82 cars. Hose routing theres 3 ways. You can replace the hose going from old res to thermostat completely, or you can cut and add in a union, or how I have it is I have it TEE'd into the heater core hose by steering shaft.
