I did a few more tests that I will outline and describe the best I can below:
1. Test setup one
* I blocked the pipe from the intake manifold but still left the Nylon lines in. This setup works fine or at least that's the first impression but when checking vacuum in the crankcase, vacuum seems be non-existent. The end of this hose is blocked.
2. Test setup two
* I removed the restriction, there's way too much vacuum applied to the crankcase which results in a whistling sound as air passes through the VC gasket.
3. Test setup three
* I installed a nut with a very small opening on the hose between the OCC and the Intake Manifold. Used a clamp on the outside of the hose so no air can go around this nut, only through. This improved the situation however, the vacuum applied to the crankcase is still too much. Please see picture below, USB stick for size reference.
Conclusion:
It seems that even the smallest opening will still allow too much flow and create a lot of vacuum in the crankcase. I believe that due to the spring in the PCV valve and the way the valve is designed, it acts as an airflow restriction because of the path the air has to take and no simple hole can achieve that.
The VTT Vacuum relief valve seems to be doing precisely nothing. Not sure if it's not allowing enough flow through inside the engine or if the spring is too hard. According to their website, they provide 3 shims with it.
No shim = 10inHG
1 shim = 12
2 = 14
3 = 16
From my testing, I can't tell if it's opening or not, tried with no shims, or with 1 shim. If I blow through it with some mouth action, it does open so perhaps it's not letting enough airflow through. The weather over here is crap as always and it's too windy to actually tell if it's sucking anything else than my energy. I will try with a vape pen to blow some smoke on it when it's not as windy to see if it's actually doing anything.
Action:
I have purchased a 2JZ PCV valve which according to
@Panzerfaust and his
post it should be a perfect fit for the an8 hose. Will update afterwards.
