There are techniques to launch at whatever RPMs you want under the fixed RPM but they aren’t consistent. Mine doesn’t bog at 3500 it just peels rubber.
Am I understand this correctly
335is with a DCT can now be programmed to
Adjust launch rpm
Adjust traction control
Can the shift firmness and shift speed be adjusted
All of this with out doing the M3 swap now ?
Am I missing anything?
@jyamona there is a substantial market for this functionality. More people are doing DCT swaps and have gone to the extreme measure of changing to M3 parts GWS DSC and diff ratios just to have this... any update? @Martial@MHDI thought this was already in a testing phase status with positive results since there are a few posts on instagram showing that works...
I really need this solution. the M3 GWS does not fit on the 1 series E82... and I don't want to have an akwardly fitted GWS not made for this car.
I rather have my car converted to manual.... but obviously that's a bad decision.
If you need testers on the MHD solution please PM me, I'm begging you.
Thanks for writing back. I was under the misguided impression that flex was a great success.Very rough "proof of concept" code was tested to verify it was possible. RPM was hard coded in the assembly code, and needed a long write to change it. Separately I tested intercepting the cruise stalk inputs and calling a custom routine. I still need to write the code to combine everything. However, I have a higher priority item from Martial at the moment.
As for there being a substantial market, perhaps. I also thought there was a substantial market for flex fuel, but that has yet to come to fruition.
Approx 250 out there right now. I guess it depends on your definition of "great success". But for the amount of time it took me, I had hoped for far more adoption by this point.
I think as this platform gets older, the cars get cheaper, and the new owners get younger, the disconnect between pricing and a quality product gets bigger. The appreciation for the expertise and time involved in projects like this falls to the wayside. Most just want it now and as cheap as fucking possible. Every time I sell something E9x related it's the same juvenile bullshit generally speaking.
BTW, that IKM0S rom has been flawless. Mdrive still isn't functional but I haven't given up. Thanks again.
Love to hear about the rom and the difference it’s made?
