Abacus38 2007 e92 335i build
Abacus38
643
385
Tampa/Orlando, FL
2007 Ti Ag 335i
Went to start the car today to check for leaks and the ECU died. Mosfets #3 is dead. I'm just going order new mosfets and dropped it off at the TV repair shop. It should cost $50 bucks at most
4,345
You are probably aware, but be careful with what they use to do the repair. I think an air station is required, if they use an iron they will ruin your DME.
Reactions: Abacus38
LoBoost
251
172
2008 135i, 2014 GTR
@Abacus38 on page 1 you mentioned getting a quick jack for your build.
How’s it working out and do you like it? I think I want one.
Abacus38
643
385
Tampa/Orlando, FL
2007 Ti Ag 335i
The ss braided lines along with some of the fittings showed up today. When the rest of the fittings show up I'll put up a DIY for ss wastegate lines.
Abacus38
643
385
Tampa/Orlando, FL
2007 Ti Ag 335i
Did some test pulls today but the car is misfiring in cylinder 3 right when full boost hits which is funny because that was the same cylinder that the mosfets died on. I have PR coils and new spark plugs but i've haven't changed the injectors yet. I'm still on Index 9 so I'm leaning to it being a bad injector. I'll swap coils and pulled the sparks first before trying to upgrade to Index 12 injectors
Nov 5, 2016
615
625
Bay Area
The S63 injectors aret’t new. My dealership has been shipping these exclusively for over a year. They have the same problems as the other index 12’s. Noticed zero difference in longevity, or performance with them. Most dealers if you order injectors are shipping these. You have to ask for the more expensive ones directly to not get the S63 version
Reactions: Abacus38
N54QC
127
67
07 E90 335i
I'm assuming since you push injectors harder than just about anybody, was curious what kind problems you experienced with them?
