6MT Launch Control
1,923
662
2 tables, one for moving, one for still? I don't really know. Just speculating...
Easiest way i think is a dead switch type setup so default no limiter but when pressed would intercept the egs signal and set to reverse or nuetral so could launch with rev limit . But sounds like theirs no reason for my ghetto tactics cause obviously it's been figured out already
Reactions: GreyNBlueE92
Amateur
Hi, guys! I play with MHD LC yesterday, and decide, that main thing is that boost pressure going up, when clutch pedal pressed. There is no any boost, when you giving revs on neutral. So, I guess, it can be useful for start.
1,286
781
Yeah, mine will build about 3psi. I think with the ability to control timing, it could make even more. Right now it's a flash time setting but I know @jyamona said it would be on the fly adjustable which would be nice.
1,048
I had a set close to 5k and Mine would build 8psi
