Does the type code have to be under the dct support codes only or can it be one of the type codes under the 6at support?xHP supports a lot of coupe type codes. The only way to check to see if your car is supported is by matching your type code to xHPs list. If its on the list, you dont have to swap vins. If its not on the list you're gonna have to swap vins.. You would have to buy both the DCT flash license and DCT maps.
Since your car is an 07, I don't think you'll be supported for flashing with your vin.
