6AT Post shift timing corrections - lets end this.
Jboyorak
14
Maine
I haven't been active for 2 years(or done anything with my car), so my memory is fuzzy right now. I am just getting back into a place where I can play with my car once more.
IIRC, I ended up fixing my issues by never reaching target boost/load. I ended up tuning everything to the point where I was always just under targets. This fixed both post shift throttle closures and post shift timing drops. How I did this...I can't remember as of right now. I know it isn't super helpful, but with any luck I will be diving back into the tuning aspect of things
Reactions: Cheezy
all4bspinnin
178
98
135i TT
Anything is helpful. I've tried this approach several times with no effect. You can lower base wgdc table/adder airflow while raising load target to do this (proving p fact doesnt make up the difference). The problem mostly surfaces on e85 due to the higher torque, timing, etc. Im working on the approach RSL recommended. I hope to have more info soon.
Reactions: mfractal
mfractal
81
27
E90 Sedan LCI 335i FBO MHD E40
i'm experiencing the same issue. FBO w/o inlets on stock turbos. I'm tuned with V8Bait, the map is super strong and i am very happy with all aspects of it, all but the corrections post shift. We've tried different E-mixtures and many map revisions but unfortunately the post shift corrections are still there.
Hopefully MHD will introduce the timing re-introduction tables to all and that will help.
here's a log of mine btw : https://datazap.me/u/mfractal/justin-e50-rev03?log=0&data=3-7-8-9-10-11-12-24
1,630
Yep. Your Cyl4 timing pull is pretty massive. Have you tried any/all of the suggestions made in this thread?
mfractal
81
27
To be honest i do not know what was done in the map to try and correct it as i wasn't tuning it myself. @V8bait (Justin) was.
Cylinder 4 does seem to be the most affected one, i wonder what that means.
BTW here's a log with more agressive timing : https://datazap.me/u/mfractal/justin-e50-rev02?log=0&data=3-7-8-9-10-11-12-24
and here's one with much less timing requests, you can see it's totally clean : https://datazap.me/u/mfractal/justin-e50-rev01?log=0&data=3-7-8-9-10-11-12-24
bradsm87
162
53
My Cyl 4 is usually the worst also. The least compromised option I can think of right now is probably to use aggressive timing reduction by charge air temp at around 5000rpm. That way at least you can get your full timing in a single gear run but pulling into a subsequent gear when IAT is higher, you can set it up to have less timing, making the drops less severe.
Still very compromised though but less so than simply pulling timing out of the timing main map.
Jake@MHD
Nov 7, 2016
1,614
2,080
Philly
So let's assume it isn't just extra noise during a shift (if so, the problem could be handled differently). Over how many ms do you think timing would need to be re-introduced in order to avoid the corrections?
bradsm87
162
53
I think 150ms would be a good starting point for testing and it's above logging sample rate so we will be able to see it in logs. From there, if timing drops get better, we could incrementally drop it back as much as possible without the bad timing drops.
Reactions: Jake@MHD
mfractal
81
27
So far it worked in an F-series test, but it was applied to every shift which made normal driving shifts slower and sloppy. It will definitely need some more work when time allows.
There's an F series with 6AT in it ? Wasn't aware..
So when you say it worked you mean post shift corrections were gone ?
BTW, you've asked above if it happens from 2nd to 3rd - just saw this this week on a friend's car. it does.
Jake@MHD
Nov 7, 2016
1,614
2,080
Philly
Not 6AT, but the logic is in the DME so trans is irrelevant. And yes corrections were gone.
Reactions: mfractal
4,345
@jyamona doesn't do engine tunes, he more or less writes code in the ecu for the engine tuners to use.
The F chassis has only had an 8HP in terms of automatics, as far as I know.
mfractal
81
27
bumping this.. has there been any development in this area or those timing reintroduction tables in MHD ?
