535i single turbo
Snertz
64
51
NY
2011 1M
The second log looks a bit better, AFR isn't tanking and trims aren't maxed out, fp_h is where it should be.
Boost is still quite a bit under target, the fact it starts dropping after 4.4k rpm makes me think there's still a leak somewhere, maybe a loose coupler.
Naldo12
42
BMW 535i
Yes is leak on the throttle body from the clip
Milan
413
241
jebi se
your mom
Just to confirm you are running the JB4 single turbo firmware AND The single turbo tune that you flash through MHD, right?
Naldo12
42
BMW 535i
You need to go into the settings on the JB4 and change the TMAP setting to 3.5bar, otherwise it won't work. This is separate from setting what map the JB4 is running.
Given the age of the car I'd highly consider replacing the HPFP and perhaps the injectors. BMW did put out a recall for both, you might be able to get the dealer to replace them for free.
Snertz
64
51
NY
2011 1M
Great, I'm glad the leak was located.
Do you have a page that looks like below? TMAP setting should be in the User Adjustment section.
JuniorB
343
112
Rhode Island
07 e60
What manifold did you use, was is built, and curious to see were the wastegate is placed. Torgus isn’t correct on all his statements. Fix those hardware issues!
Naldo12
42
BMW 535i
It custom made for the 535i
Reactions: mfractal
Naldo12
42
BMW 535i
Hi I'm having some problems with the port injection I connected but is not working can someone see if that correct thanks
Milan
413
241
jebi se
your mom
Make sure 3.5 bar map sensor is ONLY selected on JB4 and NOT on MHD!
im 99% sure that doesn’t matter. If you look at the BEF map Terry already has it set up as if you did click that. At least last time I looked on the e85 BEF it was like that.
Dumaurier7
693
316
It will not hurt to ensure it is set up like this, when I ran the JB4 it was a topic of discussion and both BMS and MHD said it should not be selected in MHD but only through the JB4 since it is the last element in the control loop.
