OK, so my official update. I literally have the entire front of the car off:
I did this firstly to facilitate cleaning the entire engine due to the cracked valvecover I had:
Secondly to make it super easy for a walnut blast and intake work:
And also to make installing the fuel system easier:
So with a clean engine compartment I heat wrapped the SNOT out of everything:
And decided it was time to test fit the kit:
I did the testfit for a couple reasons. First so I could finally see some progress on what I have tearing apart all this time. And second so I can try different install steps to see the smoothest way to get this 10lbs of shit shoved into that 5lb bag. It is tricky for sure but
@DOC_Race has made a killer kit that fits like a freaking glove. No problems AT ALL.
The VTT Shotgun on the other hand is a bit less polished (pun intended). It fits well but the details are lacking. Wrong length bolts shouldn't have been sent out. The LPFP lines are a bit...cheap. And there is some flashing/burs that could have been taken care of on the mount.
I'm also waiting on an oil drain fitting from
@Omar@VaderSolutions as I am converting all the hot-side lines to -AN fittings and SS line (we need more bling obviously). And the next three weeks I am out of town *every single weekend*
As such I'm taking my sweet time...I'll enjoy some fresh Colorado mountain air with the family for 4th of July. And after that I'll be hitting up
@jyamona and
@V8bait for an IKM0S (1M DME) flex fuel ST flash tune.
For those just tuning in, without historical context as to why I'm converting to the 1M dme it is so I can unlock MDrive and M Dynamic Mode since I just finished up a full M3 drivetrain conversion:
