The 27 psi achieved on this run was due to over boost. Setup was asking for 24 psi peak however, it hit 27 psi and contributed to this glory run. 22 psi yielded about 460 whp and 540 wtq. All in all it is a virtual dyno, we can assume plus or minus 10% at best. However, my 11.6 sec 1/4 mile run at 122 mph (1.83 sec 60') correlates nicely to the power output estimated by the virtual dyno. Again, I still have stock exhaust with secondary cats, chargepipe, inlets and intercooler. Intercooler and inlet upgrade should net another 1-2 mph trap speed.
Oh BTW, almost 0 timing pull in the last 50 pulls ive done with the last flash revision from PureEvil. Timing targets 14.5 mid range, 0.5 avg timing since I've ran this setup. Octane and complimenting hardware is key here fellas
