2017 - "Best" FMIC Thread | What's everyone running? + Data
What FMIC do you run?
  • VRSF 7.5" Race
    Votes: 28 42.4%
  • ADE 1000hp
    Votes: 9 13.6%
  • VRSF 7"
    Votes: 6 9.1%
  • ADE 650hp
    Votes: 5 7.6%
  • VRSF 7" HD
    Votes: 9 13.6%
  • ATM
    Votes: 9 13.6%
  • Total voters
    66
Silent11
124
86
2007 Bmw 335i
thank you both on your input, most of my parts are vrsf and i havent had any major issues with their parts in the past 2 years.
1,929
664
This is ade650 log from summer my temps drop when I hit gas usually and never heat soaks on pulls or under boost but when I let go gas and airflow stops even on highway cruising temps are higher on vacuum then boost.
A few tuners rec it to me and wedge publicly stated that he has seen excellent logs with ade650.
Created with Highcharts 7.1.1Amb pressure (PSI)Boost (PSI)Boost mean (PSI)Boost setpoint (-)Boost target (PSI)Coolant (*F)Cyl1 Timing Cor (*)Cyl2 Timing Cor (*)Cyl3 Timing Cor (*)Cyl4 Timing Cor (*)Cyl5 Timing Cor (*)Cyl6 Timing Cor (*)Fuel low pressure sensor (PSI)IAT (*F)Lambda bank 1 (AFR)Lambda bank 2 (AFR)Load actualLoad req.MAF Req (wgdc) (g/s)Rail pressure (PSI)RPM (RPM)STFT 1 (%)STFT 2 (%)Throttle PositionTiming Cyl. 1 (*CRK)Torque actual value (Nm)Torque Lim. activeTransmission temp (*F)WGDC After PID (%)WGDC Bank 1 (%)WGDC Base Value (%)MHD version 1.72b IJE0S THIDE_IJ_N20_HP650_93+_v04.mhd-15-10-505101520252.0K3.0K4.0K5.0K6.0K1.0K7.0KDatagraphs by SpoolStreet.com
  • 2019-09-04 17_54_06 IJE0S THIDE_IJ_N20_HP650_93+_v04.mhd.csv
Weehe
85
39
2011 335i
That's if you can actually buy one. Took 6 months to get one packaged so poorly it was damaged in transit. Another 3 months to get my money back after he wouldn't ship a new one. I paid to ship the broken one back...
Silent11
124
86
2007 Bmw 335i
are you talking about the ADE or VRSF fmic ?
Weehe
85
39
2011 335i
VRSF took ~2 months but I actually got a usable unit. Fitment is a different issue.
1,929
664
Def recommend going through a diff supplier with good rep for either of them. I got very burned by vrsf with outlets on top of the fact I paid for overnight shipping to have them forget half the order. Then they didnt fit and they wanted me send then back and pay restocking at my expense.
Silent11
124
86
2007 Bmw 335i
So far everything i ordered from vrsf took less than 4 days to get to canada, so i have no complains there, inlets and 5 inch fmic all fit fine, dci was fine as well, downpipes needed a bit of work to get them to fit properly so hoping the 7.5 fmic wont give me issues.
1,929
664
My issue was with true td04 turbos and they told me and 5 other people I know if they fot so I paid hundred for shipping and got screwed
typedRew
412
221
2009 335i xDrive
I can not recommend PSP products enough. Fit is perfect. Performance is outstanding on my 750ic
For silent setup I’d go with PSP 900ic and call it good. Pretty sure he has them in stock right now. If not a 750 would still be a massive upgrade. I barely get 15 degrees of gain in the heat of summer on mhd v5 e40 from start of a 1/4 pass to end.
I’ll dig up a log and post it
typedRew
412
221
2009 335i xDrive
PSP 750ic on mhd v5 e40 full 1/4 pass
Created with Highcharts 7.1.1Amb pressure (PSI)Accel Ped. Pos. (%)Boost (PSI)Boost target (PSI)Coolant (*F)Cyl1 Timing Cor (*)Cyl2 Timing Cor (*)Cyl3 Timing Cor (*)Cyl4 Timing Cor (*)Cyl5 Timing Cor (*)Cyl6 Timing Cor (*)Fuel low pressure sensor (PSI)Gear (-)IAT (*F)Lambda bank 1 (AFR)Lambda bank 2 (AFR)Load actualLoad req.MAF Req (wgdc) (g/s)Oil temp (*F)Rail pressure (PSI)RPM (RPM)Speed (mph)STFT 1 (%)STFT 2 (%)Throttle PositionTiming Cyl. 1 (*CRK)Torque Lim. activeTransmission temp (*F)WGDC Bank 1 (%)WGDC Base Value (%)MHD version 1.72b IJE0S e40_FBO_v5.1AT_ALP-15-10-5051015202501.0K2.0K3.0K4.0K5.0K6.0K7.0KDatagraphs by SpoolStreet.com
135iTX
115
70
2009 135i
Still on my CX intercooler (RX7 V-Mount). FBO w/ethanol and consistently trapping 121-122 in the 1/4. Total cost installed was $200 with all piping.
1,929
664
I really love the logs on this site. How does a forum do better job then a website that's only purpose is log sharing. #datazappedmyphone
Reactions: RuskiRacer
typedRew
412
221
2009 335i xDrive
I would have thought datazap would have smashed itself into an app as quick as it could, but I guess not.
I cant read their logs at all unless im on a real computer
Reactions: Rob09msport
NoGuru
1,213
597
Just North of Detroit
BMW 335is
I was doing 1/4 mile runs with a 5" ETS and temps went up 40 to 50 degrees. I installed the VRSF 7.5 Race and now they drop 15 during a run.
I quality of VRSF is crap and almost no install documentation with most of there stuff but it is hard to beat the price.
Reactions: Deleted member 2204
scrllock
267
153
2011 335xi
Have all the usual bolt-ons from vrsf, went from a catless dp to high flow and a 5" fmic to 7.5" but the only issues I had were with the 3rd party distributer the first time around, which were resolved by contacting vrsf directly. Ordered direct from vrsf and had no problems. And the 7.5 has been a champ.
Reactions: _Calle_
Asbjorn
856
605
European, based in China
Z4 N54 DCT
I posted my experience comparing the 7in, custom 7in HD and ER competition FMICs here
Tentative conclusion: Even if you are only running 400hp-450hp, you still need the largest FMIC you can get if you are ever thinking about hitting the track. On the street, any upgraded FMIC is probably OK.
My cars FMIC history goes like this: Stock - 7.5HD - 7 nonHD - 7HD "custom" - ER competition w/ water injection and water spray. The benefit of the ER fmic is that has the same frontal area as the 7.5HD / large wagner but without being stepped, so you can extend the coolant radiator down behind it. BUT I have yet to verify if this is actually beneficial to water temps or not. I have mounted a ball valve so I can turn the radiator behind the ER on and off and do A-B testing next time I hit the track this month.
When I went from 7.5HD to 7nonHD my tuner reduced timing due to excessive iats on track. I ran that setup because I wanted to test having an additional oem sized radiator in front, effectively doubling the thickness of the main radiator. I no longer run that setup, as I am now back to what is essentially a very 1M coupe-inspired configuration.
Reactions: Silent11
_Calle_
52
24
Germany
e82 135is
Running the VRSF 7" HD, and I´m very happy.
I´m still on FBO and MHD Stage 2+, next summer I will see how it works with the ST.
Silent11
124
86
2007 Bmw 335i
So i have installed the VRSF 7.5 Race fmic
did a 3rd gear pull, started at 79f and ended 3rd gear at 79f ! So far so good. However it heat soakes like a MOFO ! ambient was 55f .. iats were at 80f went up to 104f in 5 mins of idling. Is this normal ? Another 5 mins of idling it climbed up to 122f in 55f weather.
  • Dislike
