1 failed rod bearing
1,048
I recently noticed a high quantity of metal shavings in my oil filter during a regular oil change, and decided to replace the filter and check again in 500km's. Sure enough same amount of material in the filter again. Which lead to me dropping the oil pan and checking my rod bearings today. 1,3,4,5,6 look like they have equal wear but 2 is worn significantly more. # 2 also happens to be 15 psi lower in compression then the rest. Is it possible I might have a slightly bent rod causing premature wear?
