WGDC RPM x Setpoint
1,511
Been looking around and not sure I understand the utility of the RPM x Setpoint table in our wgdc control. Anyone using this that can comment on it? Does it allow for finer control by rpm as well? At face value it trades rpm and MAF. Does it matter?
Then how would one build the table? And once enabled, is the base table still used?
Jake@MHD
Nov 7, 2016
1,594
2,065
Philly
Don't use that, use the MHD+ WGDC Control. Combined with the MHD+ Custom 3D boost ceiling (which has mapswitch copies, and FF table copy it will blend against, and uses an uncapped boost target axis.)
MHD+ WGDC boost target axis is also uncapped.
1,511
Does this not use psi targets instead of load, losing adjustments for temp and atmospheric pressure?
I don't use flex fuel. The ability to have a few different maps for low moderate and high targets sounds interesting though.
