WGDC Drops. Default to WGDC Base. No PID added
WOT808
80
56
E90 335i
Hey all,
I've been having this weird issue for about a month now.
  • Symptom: Spool will slow and boost strays far from target. For some reason, the car defaults to the WGDC base value and PID doesn't intervene. Seems like some sort of limp mode (no codes or CEL).
  • Cause: This usually happens after a good multi-gear pull. I caught it happening during a pull in the log below. I can't pinpoint the trigger.
  • Temporary Fix: Restarting the car fixes the issue.
Next step is to switch to one of my older maps to see if that solves it.
Do you have any experience with this?
Car:
N54
Stock Turbos
6 speed MT
FBO + Inlets/Outlets
MHD flash (based off of an SPX file)
N20 Sensor
E50 Fuel
WMI
https://datazap.me/u/m6keharr/5-and-6-injector-swap?log=0&data=3-7-21-29-30-31&zoom=2207-2460
WOT808
80
56
E90 335i
I think this happens when PID takes too long to reach target. There's some timers in there for it I believe, then PID is turned off.
Try to set your base table as close to what it should be as possible and see if it happens then :)
That makes sense. I'll try that and report the result. Thanks!
Twisted Tuning
Oct 25, 2016
979
907
www.twistedtuning.com
N54 and N55 Cars
this is EXACTLY what the issue is. Once you exceed the timer, it bases out. there are timers for over and underboost.
OP, if tuning yourself, Zero out adders. get boost within 1-2psi of target. then adjust PID.
Reactions: Boorda and kayzrx82
tony@codewerx
172
40
E92
Whats target makes the best power top?
Usually I see 14 psi @ 7000 in 3rd in totally stock rides (no dp, no inlets, no outlets).
A lot depends on how the Vanos is tuned.
There is a proportion of effort that needs to be worked out between the engine and the turbos in hitting the VE that is targeted. Especially so if it involves stock turbos.
You have turbo outlets installed so your logs will show a better result.
WOT808
80
56
E90 335i
Let's bring this discussion back to life.
I'm still trying to find the right BLM.
Seems like 2.5 BLM was doing the job until it 'adapted' the next day. Logs below
Day 1 log
https://datazap.me/u/m6keharr/log-1509226834?log=0&data=3-5-22-29-31
Day 2 log
https://datazap.me/u/m6keharr/log-1509364320?log=2&data=3-5-22
Doesn't look like PID drop was an issue before the N20 and 3 column scaling.
The log below has a 20 psi target >6k rpm and never dropped PID.
https://datazap.me/u/m6keharr/v108-morrisville2k17?log=0&data=3-5-22-29-30-31&zoom=10754-11079
Are there any other timers to consider?
What are your thoughts?
WOT808
80
56
E90 335i
MAF change with scaling. MAF is axis on WGDC, BLM, etc. tables.
The MAF breakpoints in the tables I've looked at fit my scaled maf values well.
Is there a way to turn this PID timer off?
RSL
501
That means almost nothing, it's the values in the cells for the breaks that matter, including adders/ceiling. PID shouldn't have to do much work at all if base is dialed in.
tony@codewerx
172
40
E92
Day 1 log
Day 2 log
Try reducing the BLM more at the high end ...
chrisdfv
270
216
E90 335i
I'm struggling with this issue right now. If I set base too low, pid will match target right on, but then will time out on shift or at the top of the gear. If I raise base closer to after pid, I overshoot target/get throttle closure, but PID will continue to add wgdc instead of staying close to base. If I tune with target way out of the way and rely heavily on PID, it does not time out. I'm not sure how to approach this issue. Raise D-factor to give it a longer leash?
Boostbox
Scaled N20 flash
https://datazap.me/u/cd919/v4?log=0&data=3-6-23-30-31
https://datazap.me/u/cd919/v9?log=0&data=3-6-8-25-28-30-31
RSL
501
After PID is lower than base in the ones with the closures, so it's trying to pull, just not doing enough. If you want to run boost psi that close/on target, I'd give it more room to pull harder. Not sure the PID off was a timeout. It was on target with low WGDC and happened during shift, so I'd hazard a guess that maybe an overboost trigger kicked in. No 30FE?
You could certainly give it more room to float over target without reacting if you're not too worried about it, give it a bit more space from the target, amplify the reduction responses or some combo of all.
tony@codewerx
172
40
E92
Boostbox
Scaled N20 flash
Boostbox
Scaled N20 flash
Load request and actual looks awkwardly close.
What did you set in the BLM table ?
chrisdfv
270
216
E90 335i
I’d love to have Boost just below target but I have to ride out PID and it will usually end up reverting to base at some point.
No overboost codes. It will do this every time on back to back tries.
It’s set to 3.0
