Datalog WGDC drops at WOT, throwing 30FF
jbivens
I have a 2007 335i and when I do a WOT pull in 3rd gear or higher I'm getting a 30FF code. I have done a pressurized smoke test so I'm confident I don't have any boost leaks. I have also replaced both boost solenoids and all vacuum lines. I noticed my WGDC drops to base before my boost drops. Is this normal? What could be causing it to drop to base?
Here's the log: https://datazap.me/u/jbivens/stock-tune-0911?log=0&data=3-6-20-28-30
980
I'm not sure if this is related but you HFPF is crashing bad, it was down to 1100psi before you let off.
