VR Tuned ECU Tuning Box Kit V2 S58 +137BHP / +80BTQ
Mike @ XPH
Get your BMW M3/M4 (G80/G82) tuned with the VR Tuned version 2 tuning box kit. The tuning box kit is a plug-and-play solution to boost your vehicle's performance up like an ECU flash, but without affecting your warranty. The VR Tuned ECU Tuning Box Kit gives your BMW M3/M4 (G80/G82) again in power from 503bhp to 640bhp!
HP:
503
640
+ 137
TQ:
479
559
+ 80
Features:
Made in Germany
Plug and Play for easy installation and removal
No detection by the dealer when removed
Up to 7 different maps for easy programming
Includes bypass plug to run like stock
Does not lock to vehicle or VIN
The harness has OEM style connectors, no splicing or cutting
Tuning Box features a weatherproof case
Digital Microprocessor Controlled
Proven power gains tested on 93oct/98ron.
Designed for forced induction vehicles only.
Tuning box cannot eliminate CELs caused by modification or removal of emissions control devices such as catalytic converters.
Specifications:
Make: BMW
Model: M3/M4 G80/G82
Years: 2021+
With manufacturers trying to increase fuel economy by adding forced induction to vehicles that previously had large displacement engines, the ability to tune them further is even more prevalent now. However, there are two main issues with adjusting these newer vehicles. The manufacturers have gotten very particular about having their ECUs accessed to be tuned. These "anti tuning" features make it hard to read and write the ECU via the OBDII port. Some ECUs can be removed and flashed on the bench once the case is open. This is an immediate flag to the dealer, which ultimately will void your power train warranty if a situation arises. The VR Tuned Tuning Box Kits come into Play over the competition.
Engineered for boosted cars, these vehicle-specific plug and play kits are designed to be installed and uninstalled as needed quickly. The harnesses feature OEM plugs that attach to necessary sensors where the pre-mapped tuning box gives your vehicle massive performance gains. Unlike other "piggyback" solutions, these use high-quality connections, wires, and casing designed to be engine mounted for longevity to the elements.
Top
