User Review - Wedge Performance vs. Twisted Tuning
Status
Not open for further replies.
dyezak
1,767
1,518
Plano TX
335is
Again folks, I am reporting my experience. At no time did I ask for quick turnaround. Quality itself is expected and there is no negotiating on that. Cost is irrelevant. Tuners charge whatever, however they want and you either accept or you don't have budget. So that's irrelevant too.
Now if anyone else comes in to give obvious comments about how one should "be sure to be have clear goals for the tuner to tune".... my head is going to explode.
1. Even before tuning, all mods were explained in detail and the goal was explained:
"I have Dinan S3 under warranty for a few years, warranty is out and I heard that Dinan S3 is not that powerful so I am interested in using you to see how much more power than Dinan we can get out of this engine since it is out of warranty. I have also upgraded inlets and outlets so can you also take this into account when tuning? I also have upgraded to 3.5 tMap."
That is a summary of my talks before tuning. Now... I did NOT mention that under Wedge, my transmission went kablooey and thus I had to replace with an upgraded Propulsive Dynamics unit, which seems to be taking the tuning sessions just fine. I looked at a few Wedge logs and saw under stock tranny there were times when there was over 650nm torque... but alas, I cannot blame Wedge for the tranny failure since the original had 70K on it. Regardless, it was the daily driving or undrivability of Wedge that caused me to completely stop revisions after 12 tries. I simply did not want to risk any damage to my newly replaced engine.
And after 12 revisions... not really feeling safe with Wedge, I switched to Twisted, which feels much more smooth and less clunky but had comparable power to Dinan s3... I explained the entire process of Wedge to Twisted and he made the necessary adjustments as he saw fit. Now there is a new map that seems to be feeling very smooth and has a bit more power so I think he is make the adjustments as per my goals. I think after one or maybe two more maps, it will be locked down - smooth, controlled and more power than Dinan.
Based on your understanding of things I'm not inclined to give much credence to your opinion.
When you are saying one makes more power than the other, how are you measuring this?
Slam your foot down... one goes way faster than the other map. One is lethargic and one is violent. No measurement is necessary if it is obvious.
So I've got a question, since you aren't running upgraded turbos, have you tried just running the OTS maps on MHD by itself? The Stage 2+ with stock turbos sounds like it's really all you need. Wedge makes all the OTS maps for MHD in the latest release and if there were issues with those tunes, the powers that be and the users would have a problem.
- no disrespect to cloudblue's opinion since I was typing this as he was posting his own opinion. We don't have to agree and that's okay.
My other question would be, did you ask for some type of high output "Kill Tune" for your car that is running stock turbos?
The reason I ask, is that Wedge, V8Bait, and Twisted have numerous tunes under their belts for numerous clients and if 2/3 of the software tuners that consequently make up probably 2/3 of the custom tunes running in N54 cars are making software that isn't working in your particular car, you may have to look at starting from square one and revisiting little details.
MHD OTS tunes specifically state: "not optimized for inlet/outlet upgraded" - regardless, yes, I have tried them as well. They also feel "off" and rough... slam your foot on the floor and you get a nasty surprise with engine behavior... like it will explode.
Now... start from square one??? That makes no sense since I started from square one at the beginning. Guys, it's not like I with held info or goals from the start and tuners are trying to decipher some secret that I am not telling them.
It's very simple:
1. Wedge for me was unusable, even after 12 revisions - YES it had power, but was not usable as daily..unless I wanted to ignore the signs that the engine was making while on the tune. Slam on the gas and you get hesitation, choking, or explosion sounds... no thank you.
2. Twisted, feel much smoother and not damaging to engine, more controlled... now all we need to do is work to add more power.
If you have a great tune from Wedge, good for you. This report is not meant to push folks away from either one. There are some people who just want reports without allegiance to anyone. This is that report.
dyezak
1,767
1,518
Plano TX
335is
It's very simple:
Would it surprise you to learn that Wedge makes the MHD OTS tunes?
I literally have no understanding of tuning so that's good if you ignore me.
I am just reporting my experience, that's it.
  • Dumb
Reactions: marv85
Though I don't know anything about tuning...I am able to read...so thanks for letting me know what I already know. Please read the thread carefully before commenting, that way you don't waste your time writing things that have already been discussed.
What is wrong with some of these people? If you had a good experience with either tuner, then simply report your experience. I am not interested in debating anyone.
DennisKing
94
54
Portland, OR
If you've got poor driveability with an MHD OTS tune, you've got something else going on. It should be seemless and powerful with no surprises. I suspect something else is going on that hasn't been sniffed out yet like a component that is faulty but not giving a CEL
Reactions: Cristy7610
Are you saying you are running OTS MHD with upgraded inlets/outlets?
How do you explain the restoration to normal gas mileage and drivability under the same mods with Twisted?
See what's going on here?
cloud9blue
255
190
09 E92 335i
most likely the wgdc tables from the OTS maps is all off because inlets and outlets on his car. probably overboosting like crazy, but again, no log so this whole thread is based on speculation...
FYI op, seat of pants is not reliable for straighline performance. one car can feel a lot more violent due to sudden overboost and torque with a bad tune. does it mean it is faster than a tune with controlled boost and linear torque delivery, no...
DennisKing
94
54
Portland, OR
I actually didn't say I was running anything. I'm running a custom tune by Wedge because I know him personally and ran a shop that did some work for him in the past. I've driven numerous Wedge tunes and have yet to see any negative results so I guess that's why I'm a little baffled.
cloud9blue makes a good point. I have yet to see a log posted. Not that I could do something with it, but there have been two software tuners post in this thread already that could probably take a peek and give some input.
So I am going to ask you now: Do you still think that I would have a hardware problem now that you know that I have upgraded inlets and outlets and the OTS MHD maps are not built for this configuration?
Don't be baffled... if you are used to breathing a certain rate and you take steriods that make you go insane with urgent energy, but you don't calibrate for the fact that you also got twice as much air capacity... your lungs would probably go crazy trying to breath the same rate as before your enhancements. Too much air is just as bad and not enough.
I don't know what a log post would do since Wedge has all my logs already. He probably has more authority on the logs than any of us and yet I have a set of maps that I cannot use. Meanwhile, under the exact same conditions, from base map to this fourth map..Twisted has managed to give me a drivable car...and now with the latest 4th map, the power feels fully restored and beyond Dinan S3. I still have to do logs for the latest Twisted so he can make any minor adjustments...but as of now, I feel that there's not much more to be done except for tweaks.
DennisKing
94
54
Portland, OR
Well, Justin (V8bait) and cloud9blue both have posted in here and are also software tuners. Justin has done tunes for some very prominent N54 turbo companies with success and also had good luck with inlets and outlets on a stock turbo N54.
That's why I say post a log
So back to the question
Have you tried flashing an OTS map, like Stage 2+ on the car just to see what happens?
It takes less than a half an hour and you've already got full access to that if your getting MHD custom tunes so try that.
Reactions: PUTC
I answered that a while back. I have tried
All imaginable ots maps. Big cup of nope. And they just confirm the warnimg that they are not for upgraded inlets.
Latest revised map from Twisted is working well. Noticeable power oncrease and good control. Logged and will send to Twisted soon.
Comms with Justin at Twisted appear to be restored now that he is not distracted with personal issues. He has clarified that when he thinks the tuning is done, he will let me know.
V8bait
501
773
Texas
The tuning is NEVER done. Make sure you let him know that it's only done when every last mustang has fallen to your spinning turbos and the rivers run yellow with the corn husks sacrificed to fuel your beast.
Brutal you are.
:coldsweat::eek:
Aaron
544
200
Colorado
Silver 2013 335is 6MT
Did this need to be said? I mean, I picked up on this from your initial post.
Remember guys, he said inlets and outlets don't make a difference, so fuck your dyno sheets that show gains.
  • Dumb
Reactions: VACust
How is it you come to this conclusion? What I report here only applies to my specific situation...not universally. Obviously there have been reports of gains from inlet and outlet upgrades...why the fuck would I have even suffered through installing them in the first place?
For one reason or another I saw zero benefit and actual retarded performance after installation..and that is what I reported.
If you have them and saw gains while on stockers, them simply post the info so peple like myself can benefit from your tuner.
In the meantime, take your incredulity and lack of understanding on my comments somewhere else.
Status
