DahStig
NJ
completely forgot about this thread, smh. Too much going on. But this was thrown on the back burner. I had found one solenoid that actually was correctly rated at 300hz operation. But it was so small, it could not bypass enough flow to be trustworthy. So dropped that.
I then actually did some weird testing with a VVT solenoid from one of my old mazda engines from my TT car. Sure enough it worked. But never got around to making a housing for ports on it. But with MHD coming with the Native 3port, i never picked it back up.
Do you know if this is coming to N55 aswell or only N54 as usual?
899
Mail it to me, I can test it on my bench through the entire duty cycle range at any Hz, same day.
Would you mind sharing what you use as a duty cyle source for bench testing? I'm interested in something adjustable like you mentioned just for some experimentation.
