Trans cooler setup
4,332
I bought some of the ppkv2 pieces. This includes the oem brackets and core. I grabbed a tstat from improved racing and I'll be getting an AN fitting welded onto the oem core. That trans "cooler" which is actually a heater, is being bypassed entirely. This way it will all fit nicely including ducts from the 335is.
Reactions: slow_henry
4,332
Oh ok. So bypass the stock heat exchanger completely and use a air to air cooler (15 row) with a 180* thermostat. Might even throw a temp switch with a fan on there.
No, it will be a normal fluid cooler core, I'm cooling trans fluid with it not air(or water) in this case. And I think i did a 165* tstat.
Hassans
69
15
E90 LCI 335i N54
Do you guys monitor trans temp through MHD app or some other way?
nate335i
18
Hawaii
07' 335i
I've read so much about pressure drop (theory) when running a trans cooler.. I guess no one has actually felt the negative affects of it. I plan to retrofit a trans oil cooler to go along with my PD built trans, along with an engine oil cooler here shortly.
For my trans cooler, I have the fittings from Omar.. I need a core (15row), 165 degree tstat and appropriate lines. am I missing anything?
N54gasm
314
195
New Freedom
www.spoolnmotorsports.com
2008 BMW 135i
As with any cooler (oil cooler, intercooler, etc) you'll have a pressure drop. However, the higher quality unit/materials used, the lower the pressure drop. Get a nice cooler (not ebay $50 lol) and youll have a small pressure drop.
Nope, just a few hours for install lol
