Timing Corrections cause.
Vtecnet
14
My cars timing is clean til near 5000rpm, then it gets a bit messy.
My car has B58 Coils and B58 plugs gapped to 0.022
My tuner thinks my injector bore is bad, or injector seals, however the car has new index 12's and seals.
Anyone running B58 coils here with decent boost? what are you using for plug gap.
pbondar
437
250
I’m running g a leak of 22 psi with Nexsys B58 at 22 thou..only corrections are mid range..1-2 degrees..thinking of going the opposite way..
CalvinNismo
117
175
Sorry to hear this Charles. Long shot, but you could try indexing the plugs, it’s free and may help if the spark plugs are the cause.
The video on the Benz forum walks you though it pretty much step by step.
Vtecnet
14
Thanks i'll look into it.
