Hey everyone! Matt here from Ross Racing and just wanted to introduce a few new projects I've been working on for the past few months now!
I'm sure a few of you have already seen my Gen1 B58 Billet PCV Cap that I designed but that is just a small part of what I've been working on..
Since I started designing the Billet PCV Cap I decided that a Gen1 B58 PCV Delete Cap would only make sense as well so I started doing some research and after some trial and error I've designed 2 PCV Delete Caps with 6 setups total.
If you take a close look at my PCV Delete Caps you'll notice that an O-Ring has been implemented on the outer border to create a tight seal so you'll never have to worry about fumes escaping from the cap. Best of all, RTV Gasket Maker will never be needed, like ever.. You'll also notice that I've implemented 3 smaller O-Rings to plug the headports but the best part about this is that these O-Rings will never get damaged from being inserted/removed.
Back to the topic of design, I realize that not everyone wants to run a VTA kit, so I made sure to design OCC braces that would accommodate not only the stock/hybrid turbo folks but the topmount/BigBoost** turbo folks as well.
**for BigBoost, a stubby filter setup is required for the OCC brace to work, otherwise VTA is the only option.
So that this post does not turn into a college term paper, I'll just attach photos so everyone can see what everything looks like. Also I clearly don't have a topmount turbo so don't mind the pictures lmfao but I've checked all my measurements and I'm confident everything will clear/fit!
My site is also live! You'll find more pictures and an explanation of everything I sell on my site. International shipping also available!
www.rossrperformance.com
