Reflex Plus Full E85 Requirements
new guy
Hello Spoolstreet,
I apologize if this has been discussed before but I haven't been able to find any info regarding the requirements to run full E85 with reflex +
I'm currently sourcing all the parts required to run full E85 (at approx 620whp) & want to be sure I'm not spending money on things I don't need..
Currently I have on the way;
Phoenix Racing Manifold w/ 750 cc Injectors
Reflex Plus, Reflex bar pressure sensor & Reflex Ethanol Harness
Upgraded Fuel line from port injection to tank with ethanol sensor
I currently have a stage 2 lpfp & I've been told to run full e85 I will need a stage 3 lpfp setup. I have been looking at the spool performance stage 3 lpfp however am not sure if i need a wiring harness or hobswitch? Can the reflex plus trigger the secondary pump? If so do I just drop in the stage 3 lpfp the same as the stage 2 lpfp without any extra wiring?
& lastly, I have heard about the metal intake manifolds heat soaking and to avoid this people have used a phenolic spacer in the past, will this be necessary?
Thank you & sorry for the dumb questions
2,194
Yes you need a stage 3 aka 2 pumps for full E85.
According to: https://precisionraceworks.com/coll...ts/bmw-e9x-e8x-bucketed-performance-fuel-pump
Walbro 450 100% E85 500whp
Walbro 525 100% E85 550whp
Dual 450s 100% E85 875whp
Dual 525s 100% E85 975whp
The reflex can trigger the 2nd pump but not power it, still need a relay to the battery and wiring harness. My PR stage 3.75 v2 bucketed fuel pump in the tank came with a full harness with hobbs etc. I think I have it lying around if you want it? I don't need it as I use BMP4 for my fuel pumps.
A phenolic spacer is not a bad idea. Multiple people sell them for n54 manifolds. Make sure you get longer manifold studs. You don't need it. Air moves very fast in the IM under load. It can't hurt. my manifold came with it for free, I don't think I would pay for it. It also technically makes your intake runners longer which the general consensus is that is worse for performance, albeit probably negligible in a FI vehicle.
new guy
Thanks for getting back to me! I'm in Australia so I'm not sure if would work out cheaper to just buy the harness from Spool as im already paying for shipping the LPFP however I'm happy to pay you for the harness + shipping if it does work out cheaper, let me know how much!
This is the manifold I purchased; https://www.ebay.com/itm/2659009445...DOJfuvYUEEcAt4BXwwBq2fH5Q=|tkp:Bk9SR_6Pz6f5YA
It's not actually the 'phoenix racing' manifold however does look very similar & it doesn't include a phenolic spacer. I'll probably skip on the phenolic racer for now and see how I go.
Once again thanks for the response!
2,194
You will be just fine without the spacer.
new guy
Thanks for that mate, I might actually go with the stage 3 PR lpfp instead of the bucketless Spool system. Will I also be needing a return line + FPR?
2,194
Ugh don't go bucketless!
I have been happy with all the PR gear I have purchased.
You will not need a FPR + return at 620whp. It would not hurt, but certainly not required. I would only do it if you have future plans of making north of 700whp.
980
Personally I'd like to believe a bucketless setup done right doesn't have issues either as long as the pump heights are set correctly. I run a Walbro 450 with a Wablro 525 with the bucketless holder from PFS and have zero issues. I've done pulls with under 1/8th tank and it never loses or drops pressure.
I guess it also matters what you use the car for, maybe if your tracking the car hard you'd have issues with the basketless. From all the mountain driving I've done so far I haven't experienced anything yet.
jzx_andy
142
198
Perth, Western Australia
2008 E92 335i 6MT
I don't see any benefit to having an external FPR setup with a run of the mill ~600whp N54 build.
In any event, a Reflex+ allows one to plumb in a fuel pressure sensor and use it on one of the aux inputs, have it log fuel pressure near the PI rail, and use that to fine tune PI injector duty cycle in accordance with actual fuel pressure. That should obviate the need for an external FPR.
2,194
I still don't see the advantage of a bucketless solution fwiw. It is less expensive and you get a bit more flow right? That is the two selling points?
If you use really nice fuel mats you will NEVER have a fuel starvation issue ever again(except is you literally have ZERO fuel in your tank): https://www.summitracing.com/parts/hly-16-111 || https://www.summitracing.com/parts/hly-16-102
980
I genuinely just put 60.7 liters in my car and it didn't starve. Also yes I believe it adds a small bit of flow.
Reformatt
81
41
Houston
2010 335i E92
I have been keeping a eye on my lpfp pressure and the aux sensor I have on the dead end side of the port injection rail…so far I haven’t seen a noticeable difference in pressures..
Kinda off the topic sorry but was reading the thread an noticed the mention of the aux fuel sensor…
Reactions: jzx_andy
jzx_andy
142
198
2008 E92 335i 6MT
All good. This is relevant.
Yes, there shouldn't be much (if any) difference in fuel pressure readings between the factory low pressure sensor and one on the PI rail.
AFAIK the Reflex cannot use the OEM fuel pressure sensor as an input for scaling PI injector duty cycle, hence the need for the aux sensor. Perhaps this limitation could be overcome in the future with some updates to the Reflex or MHD, so we don't need 2 sensors basically monitoring the same thing on the low pressure side of the fuel system, but yeah.
