Propulsive Dynamics Clutches GB
N54QC
127
67
07 E90 335i
I don’t have PD transmission, is that ok with my regular transmission! I need oil change 85,000 !
Pentosin ATF1 is what I used in my stock transmission and it shifts smooth. I thought I read later it was compatible with older ZF transmission but not for ours. But I have had no issues with it in the past 20k.
N54QC
127
67
07 E90 335i
HEY GUYS WE ONLY NEED 2 MORE PEOPLE!
You should update the first post just for clarity. Wish I could get them but have no much going on in my life right now. Wonder what it would cost to get them installed.
morffius
87
16
135i
Is the external cooler needed just because of the new plates or is it recommended due to anticipated track/heavy use?
4,331
Its simply a recommendation, but if you're upgrading the transmission it was time to upgrade the cooler also.
Seaneezy
133
34
e90 LCI 335i
IIRC, The clutch material has different thermodynamic properties which makes it imperative to run the trans through an external cooler. I have attached the clutch material brochure that Jason provides.
  • ZF6HP19-21 High Performance Friction Brochure Rev2.pdf
Seaneezy
133
34
e90 LCI 335i
Are these clutches a direct drop in to our common AT. Or only for PDtrans
PD transmissions are just rebuilt 6hp21's with race bushings, these clutches, and ZF overhauled torque converter and valve body.
You can drop these clutches in any 6hp19/21, however it is probably worth it to rebuild your valve body and replace your bushings/adapters since you are already in the transmission.
Mightbaal
76
12
2008 335xi E90
I would so be in for this my friend that went to school for this stuff rebuilds transmissions but.... I am AWD so I have more than a transmission to worry about sigh I was stupid for thinking this was going to be my daily driver years ago. If I was only warned about the heroine mod problem I was going to have smh.
1,929
664
Is this still possibility and this is what I need then would send to European transmission or i put these in myself trying to clarify if this is same as the original pd upgrade ?
