Need help - stock m-sport suspension measurement
3,606
Hi all, I need a favor from someone that has an m-sport car with original suspension and wheels!
Could you give me the measurement of the fender height from the ground, at wheel center? So to be clear two measurements, one for the front and one for the rear. Take the measurement from the ground, vertically across the center of the wheel emblem up to the bottom of the painted fender well.
Any help would be greatly appreciated.
Thanks!
3,606
Yes. It needs to be a car with the m-adaptiv suspension, stock suspension and stock wheels. We are working out some things with Ohlins.
3,606
Yeah that's my problem ... all my Z4 friends are modded up lol ... thanks for asking, though, Jim!
  • Sad
JOEinSD
40
16
N54 335i
There may be one on a lot somewhere near you if no one can help from the boards.
3,606
26" even, measured by Barry when he stopped at a gas station and there happened to be a Z4 with the m adaptive suspension!
NoQuarter
1,662
1,066
Indiana, USA
Z4 35is, 535xi, X5 35i
Hmmm. Just checked mine and learned the passenger side front and rear sits higher than the driver side.
What could be the cause of this? For the front I suppose I need to make sure the strut is fully seated down into the hub assembly/knuckle (whatever is is called). For the rear... I guess the spring could be turned?
3,606
How much off? Some variation in the chassis is probably not unusual. That or you are such a badass driver that you've twisted the chassis going pell mell. lol
NoQuarter
1,662
1,066
Indiana, USA
Kind of a lot. The front is a full 1/2" !
The rear almost 3/8"
It just passed an alignment check and when I had it in the body shop couple weeks ago the whole front end was measured out with their shop body point measurement computer arm thing. So it seems it should be something relatively fixable.
Not that I care enough to mess with it over the summer. It is time to drive it until November.
Might have an aluminum outlet project though. Get rid of silicone one that I melted a bit. Not sure when that is going to let go.
3,606
Interesting ...my outlets seem finel, still. My plan is to go to aluminum when we do turbo(s).
NoQuarter
1,662
1,066
Indiana, USA
Just careless install for me. If I did it again I would have it right knowing what I know now.
I like the smaller, black VTT outlet, $100 cheaper than the PSP but the PSP looks so nice like all their other products.
Lurcher
290
168
2012 z4
I got one of the first sets from Rob (rbturbo) and the front hose is actually cut ~1 inch shorter at the top side, so the hose was sitting on the pulleys when fully installed. Rob and I went back and forth and he ended up sending me another later hose that was perfect. Same molds and everything - just weird...
