MSD80/81 SBOOT
That's a really interesting read, but from what i understand that just gives you access to SBOOT commands which is something that you can do by erasing the DME.
That bypass allows you to write custom CBOOT code in but that is already possible from a CBOOT level thanks to the RSA relocation bypass.
Maybe I'm misunderstanding it. If it's something you wanted assistance with then I can help. I do have a good decompilation if the SBOOT and some understanding of the KWP routines in there. I also have some project software that can handle the KWP comms using ediabaslib.
Reactions: 808AWD325xi
I took a quick look at the SBOOT area (0-BFFF) and I don't see any KWP routines, just calls to the KWP routines stored in the CBOOT (C000-1FFFF). Most of the SBOOT looks like the flash write routines and CAN management.
So I'm not sure this exploit is relevant to the MSD8x. I don't know how you would read and write to the DME without using the CBOOT.
808AWD325xi
21
11
Moline, IL
2009 335i
Thanks, carabuser! That's great information. I would like to read the boot password(s).
I assume those are the 2 4-byte passwords labelled as "flash_pw1" and "flash_pw2". I can read them on my bench DME but I assume they are individual to each DME?
I can send you a file that you can flash to the DME that will allow that data to be read out using INPA. What is your current DME software? Are you using MHD or another tuning platform?
fstbtstr
18
10
SBOOT on its own is not designed to let you read or write the flash, it's just allows to upload RSA-signed bootloader. I.e., it's the job of the bootloader to implement that. In the context of the SBOOT exploit, it just allows you to get the flash passwords which can be used to access the flash when you start the ECU/DME in CAN BSL mode (see TC1796 docs). I am curious if MSD 80/81 allows to write via KWP routines when CAS with valid car key is not connected.
