MHD teases N54 Antilag with the stock DME
2,194
You can see the patch notes in the app, open the side menu and hit "What's New". 3-port and single bank instructions are shown after you select the respective flash option
Single bank ST downpipe 02 is HUGE!
Is there anywhere else we can view the patch notes?
alpherd
16
Im not 100% sure but I think you would have to connect to the car to view the notes in detail. I dont have access to my car for a few weeks so I haven't confirmed. It would be cool if we had a detailed patch notes overview online that displayed changes that were made, benefits, install instruction ect for reference.
Jake@MHD
Nov 7, 2016
1,594
2,065
Philly
Here you go
Westyjeff
@Jake@MHD new update!, thanks. I just tried to flash multi map on my E93, IJEOS, but could not get the steering wheel or cruise control to activate map switch.
Jake@MHD
Nov 7, 2016
1,594
2,065
Philly
Make sure you don't have the controls blocked in the flash options, and that your last flashed map is indeed a multimap.
Also, the tach needle movement will not work on digital Kombi swaps like the ID4Motion. I emailed them the changes they need to make to support it. It still does switch maps in the background, just need to check it via current map gauge in MHD (value updates after exiting mapswitch)
alpherd
16
Car is ST, I swapped the O2s around and reset adaptations, is it normal to see these codes when single bank is active?
Jake@MHD
Nov 7, 2016
1,594
2,065
Philly
No.
1. Are you sure you selected the single bank flash option before flashing?
2. Have you removed both bank 2 sensors?
3. Are you running OEM sensors?
Reactions: carabuser
alpherd
16
No.
I checked everything over again and looks like I mixed up the pre cat wires. No longer throwing codes. Thanks! 🤙
Jake@MHD
Nov 7, 2016
1,594
2,065
Philly
A more "proper" version will be added soon-ish, but you guys have been able to NLS "well enough" for years now. Enable the shift bog and PI safety flash options and set your per gear rev limiter tables to about 200 rpm past where you want to be WOT shifting. Then you can NLS
xargentum
BMW E93 335i
Maybe you will have an option for 2step? Now Iam using jb4 because of 2step relay ( basicaly for flames when launching, or just for fun ). If you will have this option, I will join your side 😁✌️ I want to break something 😁
980
I think ima try this before replacing my trans😧, just incase it doesn't cut and i just flat foot shift😅.
