B58 MG Flasher: Switchable Maps On-The-Fly update for BMW F Series B58
Jarek@mgflasher
98
28
Canada
mgflasher.com
340i B58
MG Flasher update v234
First in the world, our entirely revised custom code for MG Flasher’s Switchable Map On-The-Fly feature brings officially support for F-Series B58. B48 and G series support will be rolling out in the following weeks. Our new custom code (v5.1) allows to switch between OTS Octane, Ethanol blends map, new Stage 2.5 (HPFP upgrade required) without the need to reflash the vehicle! Through a simple combination of the Brake Pedal, Accelerator Pedal and the Driver Select Switch you can quickly select between mapping. Please refer to OTS map release notes for which map slot contains which map.
Existing users should synchronize your App and update/flash new maps. Just before flashing you will be informed that the procedure will take approximately 3 – 4 minutes. This is a one-time flash that will not occur again unless new updates are released in this specific new code. Minimum OTS map version 2.11 is required to access Switchable Map option. Tuners should contact us about accessing Switchable Maps when using “Custom Flash Menu”.
Watch our instructional video on YouTube to see how it works and read our User Manual for details! F and G series vehicles:
Upgraded High Pressure Fuel Pump support has also been added. From the flashing menu, select the HPFP Installed option for B58TU pump, Spool Performance FX-150 & FX-180 or Dorch Engineering Stage 1 & 2. This will allow the ECU to properly control the pump. To gain any performance benefits of these high flow pumps, you’ll also need to select a Stage 2.5 map (part of Switchable Maps option). Please refer to OTS map release notes for which map slot contains Stage 2.5.
When using Stage 2.5, it is required to have an upgraded HPFP (B58TU, Spool Performance FX-150 and FX-180 or Dorch Engineering Stage 1 and 2) and downpipe. To prevent unintentional damage, do not switch to this map without installing these upgrades and selecting HPFP Installed in the flashing menu first.
Custom Code version 5.1 also bring bug fixes and improvements to Cold Start Delete, Max Cooling and Burble On-The-Fly selection. Burbles will no longer change aggressiveness (eco to comfort) on its own with engine start. Switching Burble mode on F series now requires 4 MSA presses and to return to default requires 6 presses in any mode. F and G series share the same instructions now.
Regards,
The MG Flasher Team
www.mgflasher.com
Jarek@mgflasher
98
28
Canada
mgflasher.com
340i B58
MG Flasher’s latest App, version 266, contains an important Custom Code patch (v5.4), for F-Series B46, B48 and B58 vehicles. This update will correct low torque and significantly improve performance for vehicles with Custom Code v5.x software. Please update the app from your respective app distributor, Play Store or App Store. Once you have app v266 installed, reflash your current map (OTS stage 1, 2 or Custom Map). You will be asked to confirm flashing to Custom Code version 5.4. Once complete, you should immediately see significant improvement in performance, most noticeably on the B48 platform.
The MG Flasher Team
Reactions: derekgates
Jarek@mgflasher
98
28
Canada
mgflasher.com
340i B58
MG Flasher Cloud Log Viewer
Many MG Flasher users and 3rd party tuners have requested more logging parameters; we are here to deliver! In a recent update we added advanced monitoring of boost, relative filling and injection channels. For cars that support these parameters, users may now find PID controller variables (for fine tuning boost), relative filling limiters (including an index value to help locate the source of the limiter quickly), HPFP quantity valve delivery time and much more in our premium logger! We will be updating the User Manual to include an appendix with a full list of logging parameters soon. Authorized tuners can also specify which RAM address they would like to directly log. Interested users may request access for direct RAM logging as well. Please let us know what other logging parameters you would like to see in MG Flasher!
Once users have logged their car, they may use MG Flasher’s free new MG Cloud service to upload and view logs. Our cloud log viewer enables you to quickly toggle the display of different parameters, rescale the y-axis for individual parameters, zoom on points of interest and much more! Create a free account at logs.mgflasher.com to grab your API key, copy it into the MG Flasher app under “External Services”, and get started by uploading multiple logs directly from the app! Logs on our server are sorted by VIN for your convenience and secured for privacy measures. You can also share your logs with our staff for fast support.
In an upcoming update, burble aggression and duration maps will be reworked. The lower aggression settings will now be more tame and selectable duration range has been rescaled for a 0.1 second resolution between 0.0 and 4.0 seconds.
Technical Support over the holidays will be limited between December 24th, 2020 and January 3rd, 2021. We will be back at full weekday support on January 4th, 2021 with our regular hours: 9am – 4pm EST Monday to Friday. Stay safe!
Merry Christmas and Happy New year!
The MG Flasher Team
www.mgflasher.com
Jarek@mgflasher
98
28
Canada
mgflasher.com
340i B58
F-Series B58 Stage 2.5 OTS Map Update v2.15
It has never been a better time to be a part of the MG Flasher family! Today we are announcing a new update to our Stage 2.5 OTS maps for F-Series B58 vehicles! The map has been revised entirely by improving many parameters including ignition timing, turbine efficiency, AFR, EGT control and post shift boost PID’s control to provide you safer and better performance!
Where previously Stage 2.5 was accessed only through Stage 2 switchable maps (on slot #2), you can now flash it as an independent map that is bundled with ethanol calibrations in the additional switchable map slots! The license for Stage 2.5 is still included with your Stage 2 license; you get two for the price of one. You can now select between ACN 91, 95RON, 98RON and 100RON maps as well as E30 and E40 blends. Please note, to maintain sufficient fueling requirements of the high-performance map, it is mandatory to use Stage 2.5 with an upgraded HPFP and high flow downpipe/catalytic converter. More importantly so you can serve up a nice view of your taillights to the competition! A huge thanks to all the beta users for repeatedly testing the new maps, look at their Dragy times attached here!
A few new options are added to the latest release of the MG Flasher app: Startup Roar and Torque by Gear Limiter. If your engine is warm, the engine speed will briefly increase during startup to make a “roar” sound if you choose to enable Startup Roar. You can select the aggression and duration of said roar with the new handy sliders. If you find your vehicle is having a hard time gaining traction on launch, you can also enable a torque limiter in any gear you choose. This torque limiter is extremely helpful for FWD Mini Cooper B48, which we have under beta testing, or manual transmission on RWD vehicles.
Many of you have asked about increasing the aggressiveness of burbles, with the latest app update, the aggression scaling has been increased via burble aggression styles. These styles will change the onset of aggression, how quickly the timing will retard. Try them out and see which style you like the most, not every software will have access to all styles. Together with a few other burble settings, you can find these styles in the list of customizations for burble options. Furthermore, if you want even more pops and bangs, you can add extra aggressive timing and control the fueling (via lambda) of the burble event to fine tune your flame map. The default settings are a great place to start, but we advise caution when using this new feature. This will retard timing a significant amount. Infrequent use of flame maps is recommended, please obey all local laws.
Have fun, be safe and responsible!
Regards,
The MG Flasher Team
www.mgflasher.com
Jarek@mgflasher
98
28
Canada
mgflasher.com
340i B58
MG Flasher Black Friday and Cyber Monday 2 Week Sale
We are offering 15% off all MG Flasher Licenses and our official ENET Adapter!
Available through our dealer network and at shop.mgflasher.com
Offer is valid from November 18th until December 3rd, 2021
Also, be sure to check out the new cruise control On-The-Fly features: with MG Flasher’s latest custom code users can switch maps, burbles, and max cooling using just the steering wheel buttons! In the coming weeks, we plan to release advanced antilag on F-Series B48 and B58 vehicles for both stationary and rolling launches. For a full list of available features please visit: www.mgflasher.com
Stay tuned!
The MG Flasher Team
Jarek@mgflasher
98
28
Canada
mgflasher.com
340i B58
Custom Code v7.0 for F-Series B48 Hybrids, B46, B48 and B58
MG Flasher update v358
MG Flasher is pleased to announce the release of the latest Custom Code, v7.0. This update brings support for the long-awaited F-Series B48 Hybrids! Hybrid owners will now be able to make use of all Custom Code features including Switchable Maps, Dynamic Burbles, Max Cooling and more On-The-Fly (OTF) options. Antilag is also available for B48 custom tuners who will be working on built engines. Majority of these hybrids have software version SWFL 3076-050.006.002 (R1C9I562B), however, all F-Series B48/B58 software will now be supported! More information about which software versions have Custom Code available can be found here. To gain access to the new Custom Code update, ensure you’re using MG Flasher app version 358 or newer. You can now also flash OTS and custom maps without any Custom Code, by selecting v0.0. This is useful for troubleshooting, or if you prefer full OEM functionality. In addition to the added support for Hybrids, Custom Code v7.0 also brings the following features:
  • Long term storage of On-The-Fly feature settings:
  • OTF settings will be preserved between flashes, battery changes, other maintenance tasks.
  • Requires an ignition cycle to initiate saving. Data storage is triggered when ignition is turned on. For example, set Max Cooling status, turn ignition off, wait 5 seconds, turn ignition on and it will be stored to the ECU’s long-term storage.
  • OTF settings include Switchable Map slot selection, Burble aggression level, Max Cooling status and Antilag standstill RPM setpoint.
  • Logging ethanol content when using a CAN based sensor (PT-CAN2 & ID 0x0EC)
  • Safety protocol from switching into empty slots:
  • Switchable maps and burbles OTF will prevent invalid selection, defaulting to slot 0.
The ability to save On-The-Fly settings will eliminate the need for their adjustment after flashing, providing a more user friendly and seamless integration of our On-The-Fly options. Users will no longer need to spend time adjusting their settings after every flash and will be able to enjoy their favourite setup even after flashes.
The added ethanol content logging parameter will provide users (who have CAN based sensors) the ability to monitor their ethanol content through the MG Flasher app. Any CAN based sensor connected on PT-CAN2 which uses ID 0x0EC and follows the same data format of Zeitronix’s ECA-2 CAN Bus module. You can find more details about Zeitronix’s sensor on their website: https://zeitronix.com/Products/ECA/ECA2CAN.shtml. This feature works with majority of CAN based ethanol sensors already available on the market and paves the way for the integration of our own Flex Fuel implementation.
MG Flasher is also releasing updated OTS maps for the F-Series B48 Hybrid platform: v2.2 package 91 ACN, 95 RON, 98 RON, 100 RON, E30, E40 with Switchable Map support. These maps include fueling, ignition timing and boost improvements that provide optimized results with more safe power! Refer to our Confluence based User Manual for OTS maps slot adjustment infographics here. Please note, although Custom Code support for all F-Series B48 and B58 is now available, not all OTS maps have been prepared with Switchable Map slots! Check the release notes for the OTS map you’re flashing to see if it includes populated Switchable Map slots. Eventually, all OTS maps will be released with Switchable Map support. Until then, please sit tight, we are working as hard as we can to make them available for everyone. If you cannot wait for the official release of OTS maps with Switchable Map support, you can reach out to Authorized Tuners to have them prepare it for you.
The engineering team at MG Flasher realized very early on that with the vast variety of different software versions being released, they would not be able to keep up with manually creating Custom Code for individual software versions. For this reason, we decided to move towards automating majority of the building process. This allows for a single code base for the main functionality of Custom Code, while automating the heavy lifting of applying that code to all the different software versions. When new software versions are released by OE manufacturers, we’ll be able to release Custom Code support shortly after! Furthermore, we’ve moved Custom Code to the cloud, which will allow users to download update whenever syncing their app. No need to release a new app and wait for Apple or Google to review app changes and approve the releases. For end users, this means new features, bug fixes, and updates will be released at a significantly faster rate!
With the release of Custom Code support for all F-Series B48 & B58 vehicles complete, our team has split up into two: finalizing Custom Code testing on generation 1 G-Series support for B48 & B58 and developing flex fuel support for all generation 1 vehicles. This means that once flex fuel support is released, generation 2 Custom Code will be our primary focus. With the new automation tools available at our disposal, Custom Code for generation 2 will be available even sooner! Be on the lookout for our social media stories where we’ll be looking for generation 2 beta testers!
A big thanks goes out to all the beta testers who helped in the troubleshooting and testing of the new Custom Code ecosystem! They are a fundamental part of the development process. We greatly appreciate the time these testers spent, the effort they provided and the feedback they gave to make a better experience for you. We thank everyone for their hard work and dedication in helping us provide a finished product that we are very proud to share with you today!
Happy Flashing!
The MG Flasher Team
Stage 1 OTS v2.2 Switchable Map Slots for Gen 1 F-Series B48 Hybrid
Stage 2 OTS v2.2 Switchable Map Slots for Gen 1 F-Series B48 Hybrid
