Datalog Measuring Oil Level through MHD
586
In the "S55 Pan on an N55" thread @houtan mentioned that user fe1rx did some work to figure how to measure oil level through diagnosis. You can check here
A new way to manage oil levels on Track
I asked Carabuser if we can add a channel to MHD and Log our oil level.
Put this line in your INA0S_UserChannels.xml file:
Code:
  <ActualValue ReqBlock="D9,5E" Size="1" DataA="0.29296875" DataB="0.0" Prefix="C0" Units="mm" RoundingDigits="2">
    <Text xml:lang="en">$ Oil Level</Text>
  </ActualValue>
Maximum sensor reading is at 74.7mm.
The levels seem to vary between software versions, but on INA0S you'll get the full status (probably over full) at 74.7mm and the add oil message below 41.7mm? 41.7mm seems low to me, maybe I'm reading the logic wrong.
I added the line and went for a test drive. During driving it probably doesn´t give tonss of useful information but i figured that it actually is sending information quite regularly and that way you can check anytime your level while standing and correct if needed.
Thanks to @carabuser fo his quick support and giving that nice feature to us :)
I copied the table from fe1rx so you can save it and compare quickly.
Here is my log:
houtan
630
312
135i N55 DCT; PS2
Here is my log:
Nice!!! Do you know if this will work for e series n55 98G0B rom?
KClemente
289
147
E90 335i
Been using it for the better part of a year now and its funny and slightly terrifying seeing the gauge massively drop during heavy braking.
There are a lot of monitors regular people and even track guys would like, for example long, lat acceleration sensors, battery voltage, brake pressure etc.
I'm honestly more surprised even mhd didn't include battery voltage (vb) in the monitors
Reactions: JohnDaviz
586
Sorry. I don´t know. But if you can read oil level through other apps/devices and can add custom channels to your mhd logging, then i am pretty positive. Just can´t help you here cause i have no clue :(
Reactions: houtan
586
Hell yeah! My oil level dropped to single digits sometimes and my eyes just went directly to the oil pressure reading.
May be we can get @carabuser some beers for some of those ideas you mentioned. Would be really cool actually.
Reactions: jzx_andy and wheela
1,594
2,065
When days start having 48hr each, I will have enough time to add everything desired to every MHD platform. Until then, we do our best :).
Most platforms don't even allow you to add your own logging parameters lol.
houtan
630
312
135i N55 DCT; PS2
Tried it. Breaks logging when selected. Anyone want to help us find the correct address for 98G0B? Would be really cool.
KClemente
289
147
E90 335i
That's how you know y'all need to hire another engineer 😮💨
But in all seriousness, my comment was more geared towards when you guys were still developing and when the N54 was the main platform for MHD
houtan
630
312
135i N55 DCT; PS2
that sucks. But yeah i thought that the addresss will be different. Maybe @Jake@MHD will have a few minutes to give that information?
That would be awesome.
Honestly, I know at least three people that would be willing to put in the work to find this info out for e series n55. We just have no clue where to start.
suspect
I use MHD on iOS and only have flasherOptions.xml in the MHD directory. Do you just create a new file called UserChannels.xml in the root directory? This level is what I see in INPA and measured it once when refilling oil. Will try to dig it out.
Anon1
10
18
2013 135i DCT
This sounds interesting and I would be willing to lend a hand. I have a bunch of docs/al2/damos that I can share. If we get a few heads together, I'm sure we can figure it out.
I think the approach for this is:
- Find the routine for oil measurement
- Find the name of the of the oil level value
- Find that address in the 98G0B/9E60B by using the closest damos
- Define the custom UserChannels.xml
I started a thread on the N55 side, https://www.spoolstreet.com/threads/measuring-oil-level-through-mhd.9335/
desmo11
On oil level, you'll want to look at the level in a xyz plot, lateral g's as x, longitudinal g's as y (or accel m/s^2) and level as the z channel. Really the level is only accurate around say 0-0.2 g lat/lon accel. On vehicles with more traction one really needs to look at baffling or dry sumps.
For a 1g lat accel, your oil free surface will be at a 45 deg angle opposite the direction of turn. Under such conditions you don't want to uncover the oil pickup (and thus experience oil pressure dropouts).
suspect
This is what I found from INPA when refilling
0 litres = about 0 mm - below minimum and add +1 qt
1.5 litres = 9.5 mm - below minimum and add +1 qt
3.0 litres = 53 mm - below minimum and add +1 qt
5.0 litres = 74 mm and OK
Might have gone a little too fast between 3 and 5 litres as the oil falls into the sump and takes time to register. Reading between 3 and 5 litres might not be accurate because of this.
suspect
Anyone know the address for oil level measurement for IA80S? Tried D9,5E as above but does not work on my 2007 335i.
Reactions: studio54
studio54
69
31
Interesting logging parameter, thanks 👍
is it specific to INA0S or can it be used on I8A0S too ? anyone tried?
if not, @carabuser do you have the I8A0S by any chance ?
(I like those custom parameters, for example, on a different note, you can find the "AFR target" that might be useful given by carabuser too in the AFR oscillation thread)
Reactions: suspect
Change the req block to D2,74. I'm 99% sure it's that address on I8A0S.
Reactions: studio54
samuria
I also would like to know this. I have IJE0S_UserChannels.xml AND UserChannels.xml (both because I wanted to find out if removing IJE0S would work) in the MHD root directory, but see no changes. Does this xml config file only get picked up on Android?
