M-Drive and MDM in non M cars
amg6975
278
187
2012 135, 2005 ZHP, 2009 fJCW
Is all that based within the DME?
If so then the symbolic name for M_ACT_2 is St_mdrv_anz. The description for St_mdrv_anz reads "The MDrive display in the Kombi is controlled via this signal."
Yeah, correct. What I called M_ACT_2 just signals the KOMBI to display the M, people have this working. The M_ACT parameter is what's missing from IKM0S to actually enable M Drive in the JBBF (Servotronic) DSC, and DKG.
amg6975
278
187
Hey while I have you, any clue how "CHKSUM_ST_MDRV" is calculated?
OK starting to make sense now. STATE_SPT_DISP_CAN is moved into CTR_DISP_MDRV. This section should be really relevant for you:
Reactions: amg6975
I've only worked out the code checksums, not looked at the comms ones. I might be able to find how they are done, I'd imagine they are simple to reduce overheads, the other code checksums are quite complicated but they are only checked once, not 100 times a second.
amg6975
278
187
Yeah I think it's tied to the counter some how, I just can't figure out the exact logic...
Where do you get the CAN message documents like above? That would be insanely handy to have. Found it. In the Continental Doc.
Here's a log of pressing the M button a bunch of times. I can't get a handle on the checksum:
ARBIDBYTESD0D1D2D3D4D5TIMEDELTA T
0x399
6​
0x890x010x000x220x410x87
659.8042​
0.16​
0x399
6​
0x770x010x000x220x410x87
659.6442​
0.16​
0x399
6​
0x660x010x000x220x410x87
659.4842​
0.59​
0x399
6​
0x570x020x000x220x510x87
658.8942​
0.16​
0x399
6​
0x460x020x000x220x510x87
658.7342​
0.16​
0x399
6​
0x350x020x000x220x510x87
658.5742​
0.69​
0x399
6​
0x220x010x000x220x410x87
657.8842​
0.16​
0x399
6​
0x110x010x000x220x410x87
657.7242​
0.16​
0x399
6​
0x000x010x000x220x410x87
657.5642​
0.63​
0x399
6​
0xE10x020x000x220x510x87
656.9342​
0.16​
0x399
6​
0xD00x020x000x220x510x87
656.7742​
0.16​
0x399
6​
0xCF0x020x000x220x510x87
656.6142​
0.64​
0x399
6​
0xBC0x010x000x220x410x87
655.9742​
0.16​
0x399
6​
0xAB0x010x000x220x410x87
655.8142​
0.16​
0x399
6​
0x9A0x010x000x220x410x87
655.6542​
0.65​
0x399
6​
0x8B0x020x000x220x510x87
655.0042​
0.161​
0x399
6​
0x7A0x020x000x220x510x87
654.8432​
0.16​
0x399
6​
0x680x020x000x220x510x87
654.6832​
0.68​
0x399
6​
0x550x010x000x220x410x87
654.0032​
0.16​
0x399
6​
0x440x010x000x220x410x87
653.8432​
0.16​
0x399
6​
0x330x010x000x220x410x87
653.6832​
0.6​
0x399
6​
0x240x020x000x220x510x87
653.0832​
0.16​
0x399
6​
0x130x020x000x220x510x87
652.9232​
0.16​
0x399
6​
0x020x020x000x220x510x87
652.7632​
0.98​
0x399
6​
0xEF0x010x000x220x410x87
651.7832​
0.16​
0x399
6​
0xDE0x010x000x220x410x87
651.6232​
0.16​
0x399
6​
0xCD0x010x000x220x410x87
651.4632​
1.081​
0x399
6​
0xBE0x020x000x220x510x87
650.3823​
0.16​
0x399
6​
0xAD0x020x000x220x510x87
650.2223​
0.16​
0x399
6​
0x9C0x020x000x220x510x87
650.0623​
0.56​
0x399
6​
649.5023​
0.159​
0x399
6​
649.3432​
0.161​
0x399
6​
649.1823​
0.98​
0x399
6​
648.2022​
0.16​
0x399
6​
648.0422​
0.16​
0x399
6​
647.8822​
9.102​
I've found where the MDrive stuff is done in IDA so I might be able to follow it to see how the checksum is done.
That last screen i sent has a clue about it: CHKSM_ST_MDRV = CRC_CLC_CAN_STMDRV (Standart 4bit checksum)
There's no symbols for it so I'll only be able to find it if it's close to the MDrive logic in the execution order.
AzNdevil
567
270
Hong Kong
Reactions: RSL and amg6975
amg6975
278
187
Man, I haven't done any assembly in two decades haha. English?
2,251
805
I have a late 2009 EU DCT 335i
There never was a 335is in Germany. It was just the standard car and you could order it simply with a DCT.
How can I check if my DSC is capable of being properly working after coding or if I need another module?
You should be fine
Looks like @AzNdevil is right in that there's no logic for writing to that area of the telegram. I'll keep looking for a bit to see if it's something that could be added in.
Interested to see all the different DSC modes though. One thing that really bugs me about my 335i is how invasive the DSC is. My Z4 puts the power down much better and also manages slip a lot better. I'm sure some of that is tyre and chassis differences but most of it is the DSC killing power way too much.
Olza
232
231
Minsk, Belarus
BMW 320d
@amg6975, looks like tricore mnemonic, good.
0. clear low four (crc) bits in byte0 of canarray(6).
1. Crc int16 = 0x399, i = 0
2. crc = crc + canarray(i), i++, Loop i<6
3. Tmp = crc >>8 (ie crc 0x854 = tmp 0x08)
4. Crc = crc AND 0xFF (ie crc 0x854 = 0x54)
5. Crc = tmp + crc (just add low and high bytes of initial crc = 0x5C)
6. Tmp = crc >>4 (0x05)
7. Crc = crc AND 0xF (0x0C)
8. Crc = tmp + crc (0x11 sum of high and low quarter bits)
9. Crc = crc AND 0xF (crc = 0x01 to fit into 4 bits crc)
Example:
1. clear low (crc) bits in 0x89 = 0x80
2. Calculate sum of all new bytes = 0x16B
3. Add can id: 0x399 + 0x16B = 0x504
4. Add low and high bytes to byte = 0x09
5. Add low and high quarter bits in byte = 0x09
6. Mask low four bits: 0x9
7. Insert in crc field that four bits.
8. damn! 0x89 ))
upd: as i can see, DCT did not check crc, only alive counter.
Reactions: AzNdevil and RSL
amg6975
278
187
You may be able to code the friction coefficients in the DSC to allow for more slidey. You certainly can adjust MDM, but I’m not sure about “On.”
Example:
8. damn! 0x89 ))
Awesome, thank you! I want to make sure I/we fully understand the ins and outs of M Drive before I tear down my M3.
Reactions: aus335iguy
2,251
805
That’s why M3 coefficients are the ones to have. Pretty sure they’re different between “on” and MDM and both sets can be moved across to “on”and DTC on a non M respectively
2,251
805
@amg6975
I know you’re probably chomping at the bit to get stuck in to that thing. I really appreciate doing this for the common good mate. You’re a champion
amg6975
278
187
@amg6975
No worries. Understanding how the iDrive sets the M Drive parameters is a bit self serving because I won't have iDrive in the M1.5 but I probably will make a CAN module to configure them.
AzNdevil
567
270
Hong Kong
yes it is possible to code the friction coefficients but the values from a m-dsc is not in the list in a non-m dsc
i looked into this a few years ago but i havent tried to forcefully change it through nettodat
i am not sure if it will work since the coding is just referencing from a preset list of parameters which we cant see...
eg. steering angle characteristic curve, values from both mk60_87.c0a and mk60_m3.c0<X> both refer to values 00 01 02...
imo the most annoying thing is if you do a servotronics retrofit with a m3 steering rack, traction control keeps on cutting in and apply brakes if you turn the steering wheel too fast (eg. crank the wheel hard at 40-50 km/h into a 90 degree corner) the car isnt understeering but with squealing track pads you can hear the brakes being applied
2,251
805
Nettodat coding was what i was getting at yes.
Ive long wondered how having an M3 rack without the SZL would behave. I think this is a key point that people miss. The SZL encodes the steering angle and tells the DSC how much the wheels are turned. If you change the rack ratio this goes out the window. So a question for later would be if the SZL has a parameter that can be coded relating to steering rack ratio.
AzNdevil
567
270
Hong Kong
i logged from the szl and the wheel angles are actualyl correct without changing to a m3 szl but... on the m-dsc program its in the coding
however, this implies the brake pressure calculations in the dsc will be off if a m-dsc or m-dsc program running on a non-m dsc
another thing would be the different sized valving in the m dsc hardware compared to non m, different master cylinder, different caliper diameters, and the list goes on and on........
tldr; it is possible when mdm kicks in, too much brakes get applied and make things worse, but then it might not be a problem especially for guys with bbk since most kits out thre throw all of these considerations out the window
