IS right engine mount now $679!!!!!! WTF?
3,596
Sheesh. My Revshift mounts are extremely rattle-y as well. I also made the mistake of going with their transmission mounts thinking the DCT wouldn't cause much vibration... LOL... Rogue Engineering mounts are the only thing I recommend at this point.
I keep saying this and people keep having a love affair with everything polyurethane. Transmission mounts in anything other than rubber are the devil.
$700 motor mount conversation is as absurd as a $10,000 motor mount conversation.
derekgates
740
375
NW FL
derekgates.us
2011 335is
For sure, I rarely recommend poly. I have it in my rear subframe and a couple spots such as top strut mounts, otherwise flex is a good thing. I'd love to collect a list from you and @Asbjorn for 'what to use where'... I think you two have posted the most about recommendations!
For engine mounts going OEM is wallet busting so mounts like poly were a worthwhile experiment. I am amazed at the build quality of Revshift but sometimes my teeth get knocked out.
Transmission mounts? HELL NO. Stay rubber. You want some deflection! :)
Asbjorn
854
602
European, based in China
Z4 N54 DCT
Gotta say the brand new 034 motor and transmission mounts look pretty awesome. (EDIT: I was wrong about 034 read below posts) Would love to try mounting one of each on the passenger side. I wouldn't dare to do both sides neither for engine nor dct though
BTW if already purchased, you can actually use poly with the dct as long as you only do one side. Both sides is a big no no. But I would still prefer upgraded rubber for dct.
I currently run one passenger side green revshift motor mount and I don't like the vibrations. But the car is super fun to drive through corners, because there is less engine weight transfer. The softer poly isn't an option because it melts on track. So perhaps the new 034 is a good alternative to an IS mount.
As for the rest of the car... use M rubber everywhere if you want sporty comfort. And remember to avoid camber plates (nvh!!). Or go all in and use bearings everywhere if you want that ultra sharp response. Then you also do camber plates and track ready alignment to make the car extra pointy. And you'll both love and hate it. Depends on the use and roads available.
Poly can be used for swaybars (hard or soft poly) and if necessary as diff mounts (need soft poly - noone wants diff whine). Subframe mounts can be solid no problem imho. Rear strut mounts I haven't tried upgrading yet.
Otherwise avoid poly - and definitely never use soft poly for suspension arms. Its rubber, bearings or hard poly as the very last option.
  • Love
Reactions: derekgates
Holy crap - $679 at FCP
SKU: BMW-22116793240
BMW Engine Mount - Genuine BMW 22116793240
335is, Z4
Save for later
Available
In Stock
Discount
Price each: $679.00
Options?
I just ordered one. There is no way in hell I am going to risk missing out on this price again. $308 plus tax.
I suggest you guys get one while they last.
  • Wow
derekgates
740
375
NW FL
derekgates.us
2011 335is
UGH I really don't have the money for this, but I can't pass it up again. Son of a...
1,267
771
No, I had the 034 street density mounts that everyone had when they came out. They felt like stock as far as nvh, but are likely weaker than stock as everyone that had them has them break in under 5000 miles.
I now have a bfi stage 1 mount. It is poly, and it's a rattle trap. A REALLY BAD result trap.
Reactions: Asbjorn
3,596
Reactions: Asbjorn
derekgates
740
375
NW FL
derekgates.us
2011 335is
