***Group Buy*** MFactory SMFW and Twin Disk
MFactory
245
140
Hey guys,
if you have an 06-Jan 09, then you need the 8-bolt flywheel
If you have a Feb 09+, then you need the 6-bolt flywheel (if it's a 2011+, you need to press out the included centre pin)
For those who ordered the Twin-Disc clutch:
We have the 6-puck solid and 3-puck sprung in stock. Our 6-puck sprung will be around end of April
For installation:
- Make sure to disassemble the clutch/flywheel before installation
- You MUST install the flywheel first. Torque specs for the flywheel bolts are same as oem, as you are re-using the oem bolts (or you can purchase separately. We have them in stock)
- After installing the flywheel, you can then install the clutch (using the provided alignment tool). You can re-use or purchase a new oem throwout bearing from ECS etc
- When installing the clutch cover, this must be flush against the included washers. These washers are there to allow you to adjust the engagement as the clutch discs wear down. Double-check to make sure each washer stack (there are 6 stacks) have the SAME amount of washers, otherwise, this will create more NVH and uneven disc wear
