Got the new Amazon Fire TV Stick
4,331
Time to put Kodi on this piece, let's see if @omarmarji know wtf he's talking about
4,331
For anyone who wants to know how, and has an android device or a Fire TV Stick, the instructions are here, follow the stable instructions:
How to Install SALTS Kodi (stable):
  • Open Kodi
  • Select SYSTEM > File Manager
  • Select Add Source
  • Select None
  • Type the following EXACTLY http://fusion.tvaddons.ag/ and select Done
  • Highlight the box underneath Enter a name for this media Source, type fusion & select OK
  • Go back to your Home Screen
  • Select SYSTEM
  • Select Add-Ons
  • Select Install from zip file
  • Select fusion
  • Select xbmc-repos
  • Select english
  • Select repository.tknorris.release-x.x.x.zip
  • Wait for Add-on enabled notification
  • Select Install from repository or Get Add-Ons on Helix
  • Select tknorris Release Repository
  • Select Video Add-Ons
  • Select Stream All The Sources
  • Select Install
The Stream All The Sources add-on is now installed and ready to use. As usual the add-on now can be accessed via VIDEOS > Add-Ons > Stream All The Sources from your home screen.
After installing I recommend using the Auto-Configure feature which does a range of things that help make SALTS even better
  • Select Settings
  • Select Auto-Configure SALTS
  • You will now see a list of all the features that the auto-configure setting changes. All the settings are checked by default but you can deselect any of the changes that you don't want to change but for most users I would recommend just leaving it as it is
  • Select Continue
  • Wait for Auto-Configure Complete notification
  • Select Add-on Settings
  • Select Source Management
  • Change Source Selection Method to Directory
  • Select OK
SingleTurboE92
199
108
Aubrey, Texas
I have Kodi on an android box in my theatre room and it is amazing. Glad to see it is programable on the new fire stick. Might grab one of these for the garage TV.
