F8X S55 PURE Stage 2 Turbo Upgrade - Results Thread!
Steve @ Pure
31
33
F80 M3
Hey guys,
Here is some dyno results and 1/4 mile numbers for F8X S55 Pure Stage 2 with different mods and fuel set up,
-1st F82 S55 M4 build by Tpg Tuning
Mods:
-TPG Built S55 LongBlock Including Ported Head
-TPG Billet One Piece Crank Hub W/ Modified Damper
-TPG Race Exhaust
-TPG Custom Ice Tank Setup
-Fuel-It Port Injection and Proto-Type LPFP
-PureTurbo Stage 2
-Evolution of Speed Billet Intercooler
-Evolution of Speed Billet Intake Manifold
-Dodson Motorsports Clutch Packs
-Driveshaft Shop Axles and Driveshaft
-HC Performance Back End Flash
-Burger Tuning JB4 - Custom Firmware
-Burger Tuning Intakes and Charge *****
-Weld RTS Wheels - Hoosier Slicks
Dyno results: 745whp / 720wtq
--2ND F82 S55 M4
Mods:
-PureTurbos stage 2
-E30 fuel (93 pump gas mixed with E85 fuel)
-FBO
-BMS JB4
-BEF by DME Tuning
-SSP performance Spec-R clutch pack
Dyno results: 729whp / 701wtq
-3Rd F80 S55 M3 Build by Sport Mind (Bahrain)
Mods:
-PureTurbos stage 2
-FBO
-BEF by DME Tuning
-Race gas
-JB4
Dyno results: 698whp / 668wtq
--4Th F82 S55 M4 Build by Sport Mind (Bahrain)
Mods:
-PureTurbos stage 2
-FBO
-BEF PTF (BootMod3)
-Fuel-it Port Injection
-JB4
-Dodson clutches upgrade
Dyno results: 703whp / 737wtq
-5Th F82 S55 M4 build by Caribbean Autowerks
Mods:
-PureTurbos stage 2
-FBO
-JB4
-EOS watercooler
-E85 fuel
Dyno results: 722whp / 712wtq
-6Th F80 S55 M3 build by AutohausFrankurt
Mods:
-PureTurbos stage 2
-Fbo
-91 oct only
-Tuned by Mission performance stage 3 Flash
Dyno results: 615whp / 630wtq
-7Th F80 S55 M3 build by AutoCouture
Mods:
-PureTurbos stage 2
-Fbo
-E40 Fuel
-BEF by ACM Tune
-Jb4
-Dodson Clutches
Dyno results: 659whp / 676wtq
-8Th F80 S55 M3 biuld
Mods:
-PureTurbos stage 2
-93 oct (gas pump)
-tuned by Eurocharged Canada
Dyno results: 611whp / 545wtq
-9Th F80 S55 WideBody M3 (Track setup)
Mods:
-PureTurbos stage 2
-FBO
-Jb4
-BEF by PTF (Bootmod3)
-91 Octane only
-CSF Cooling system
Dyno results: 600whp / 597wtq
-10Th F82 S55 M4
Mods:
-PureTurbos stage 2
-BMS Meth Kit
-BMS JB4
-FBO
-100 shot of NOS
-Back end flash PTF (bootmod3)
-DCT Flash PTF (bootmod3)
Dyno results: 763whp / 776wtq
-11Th F82 S55 M4 build by Speed Motoring Solutions
Mods:
-PureTurbos stage 2
-Race Fuel
-BMS JB4
-FBO
-SSP clutch packs
Dyno results: 647whp / 629wtq
Here is some 1/4 mile Numbers
-1St World's First 9 Second F8X M3/M4 by Tpg Tuning
Mods:
-TPG Race Exhaust
-PureTurbo Stage 2
1/4 mile results: 9.98 @ 145.02
-2Nd F80 S55 M3 6 Speed build by Tpg Tuning
Mods:
-PureTurbo Stage 2
-FBO
-Jb4
-Fuel-it
1/4 mile results: 10.86 @ 129.42
-3rd F80 S55 M3 by Maximum PSI
Mods:
-PureTurbo Stage 2
-FBO
-Jb4
-BEF (Maximum psi)
-Hoosier Slicks
-Full E85 fuel
-Dodson clutches
-Fuel-it LPFP with EOS manifold
1/4 mile results: 10.278 @ 137.15
4Th F80 S55 M3
Simple mods:
-PureTurbo Stage 2
-BEF Precisiontunig
-Dodson clutches
-Race Fuel
-Intakes
-Exhuast
-Jb4
"NO Meth Or PI, ONLY race fuel"
1/4 mile results: 10.2 @ 136 MPH
Also we have 1/2 mile Numbers
F82 S55 M4 build by fuel-it
Mod:
-Fuel-It! Platinum Port Injection kit
-Fuel-It! Platinum LPFP upgrade
-Fuel-It! Ethanol sensorJB4 (Stage 3)
-Pureturbos Stage 2
-FBO
-BMS Oil Catch Can
-Dobson DCT clutch upgrade
-CSF heat exchanger
-Bootmod3 backend flash
-Running E85
-Toyo R888 tires
1/2 mile results: trap speed -172.8
Bmwfixerguy1
875
292
07 335i MT
I absolutely can not wait till the f8x cars become second hand affordable!
I've been with BMW as a tech for 3 generations of new M3s.. This is not only the best by far but the first one that every tech just drools over..
4,332
I've never been in one. I thought the S65 was cool mostly for its displacement, but the boost is nice. What do you think of the S55?
Bmwfixerguy1
875
292
07 335i MT
Well ever M engine has had literal engine problems that BMW in good ole BMW fashion ignores and pretends isn't really a problem and does the usual blame it on the clients.. With the s55 so far the known problem is the timing chain hub on the front of the crank. It's secured to the crank with no key of any kind just a small friction disk. Basically a very thin shim impregnated with "grit" so when you torque the crank bolt it keeps it timed... Or so it's supposed to lol.. Lots of aggressive down shifts and apparently just like axcwl has caused them to slip and trash heads by bending a bunch of valves. Bmw has blamed a bunch on the client so far.. Other than that that are silly fun to drive..
Look at those numbers above that almost look too damn easy!
